Hi
I just got myself a Google Nest Hub and I was wondering if it was possible to control it from HA?
For example turning off the screen or requesting to display some data like the weather (using the normal UI, not casting!)
Check out
Hi, thanks for the link I’ll have a look!
Just in case anyone comes across this thread and falls into the trap of trying to set up Assistant Relay (it hasn’t been maintained for a few years and Google auth changes appear to have broken the user setup process) - as of 2023.1 this is supported natively by Home Assistant:
