Possible to disable Scenes as a default in Widget?
I quite like to use the iOS Widget to quickly do some things in my home automation.
Since I also use deconz, I have a number of Scenes that are automatically created there and that are enabled as a default in the app and thus visible in the Widget. Is there an option to disable them as a standard or choose which scenes should be enabled centrally (just like I would configure actions centrally in configuration.xml)?
Regards,
Peter
You can turn off individual Scenes in the App Configuration, and you can long-press and configure the Widget to only include certain Actions if you want to use a specific subset there; the default is just to include all that it can.
