Possible to have two displays? Or rotate a screen page?
Is it possible to have one display with config for the screen landscape.
Then be able to go to a specific page and that page be in portrait ?
I tried it with two displays, but every 5 seconds it flashes between them both.
I have tried this thread Oled display rotation based on a sensor however, it appears the “rotation” can’t be templated.
Or just have multiple screens?
display:
  - platform: st7789v
    backlight_pin: GPIO4
    cs_pin: GPIO5
    dc_pin: GPIO16
    reset_pin: GPIO23
    rotation: 270 //Be able to make this custom
    update_interval: 1s
    pages:
      - id: page1
        lambda: |-
// Screen 2 (does display, but automatically cycles between screens
  - platform: st7789v
    cs_pin: GPIO5
    dc_pin: GPIO16
    reset_pin: GPIO23
    rotation: 0
    update_interval: 0s
    pages:
      - id: page99
        lambda: |-
Anyone…?
Any thoughts?
Pretty certain neither will work, as the rotation is not templatable and set at compile time.
Have you actually tried the 2 screen idea?
Yeah I think the only way would be to rotate everything within the lambda if that’s even possible.
Yes did try it, bit just “flashes” the second screen every 5 seconds or so.
Did you ever figure out a solution here? I’m chasing down the same goal here and running up against the same problem.
edit: OK figured out a solution here :smiley:
      - id: page4 # PM10 graph
        lambda: |-
          it.set_rotation(DISPLAY_ROTATION_270_DEGREES);
Filling this out a bit more, here’s how I managed to get a display to rotate via button press:
globals:
  - id: global_display_rotation
    type: esphome::display::DisplayRotation
    restore_value: yes
    initial_value: 'DISPLAY_ROTATION_0_DEGREES'
button:
    on_press:
      then:
      - lambda: |-
          switch (id(global_display_rotation)) {
            case DISPLAY_ROTATION_0_DEGREES:
              id(global_display_rotation) = DISPLAY_ROTATION_90_DEGREES;
              break;
            case DISPLAY_ROTATION_90_DEGREES:
              id(global_display_rotation) = DISPLAY_ROTATION_180_DEGREES;
              break;
            case DISPLAY_ROTATION_180_DEGREES:
              id(global_display_rotation) = DISPLAY_ROTATION_270_DEGREES;
              break;
            default:
               id(global_display_rotation) = DISPLAY_ROTATION_0_DEGREES;
      - component.update: my_display
display:
  - platform: st7789v # 135x240
    model: TTGO TDisplay 135x240
    cs_pin: GPIO5
    dc_pin: GPIO16
    reset_pin: GPIO23
    rotation: 90
    pages:
      - id: page1
        lambda: |-
          it.set_rotation(id(global_display_rotation));
Thanks!
Will give it a try.
I can’t get this to work.
When I view the page99, it rotates all other pages until I get back to page99 then rotates again.
The button doesn’t do anything.
Can you share your full condig?
This worked for me thanks!
Doe not work for me. I only get:
[lambda] is an invalid option for [pages] ???
# SELECT
select:
    entity_category: config
    options:
     - "0°"
     - "90°"
     - "180°"
     - "270°"
    initial_option: "0°"
    optimistic: true
    icon: mdi:phone-rotate-landscape
    on_value:
      then:
        - lambda: |-
            switch(i) {
              case 0:  id(my_display).set_rotation(DISPLAY_ROTATION_0_DEGREES); break;
              case 1:  id(my_display).set_rotation(DISPLAY_ROTATION_90_DEGREES); break;
              case 2:  id(my_display).set_rotation(DISPLAY_ROTATION_180_DEGREES); break;
              case 3:  id(my_display).set_rotation(DISPLAY_ROTATION_270_DEGREES); break;
        - lvgl.widget.redraw:
Hi, i’m trying to be able to rotate my TTGO T Display screen 180°.
I want to use lvgl.
I’ve tried this code but it doesn’t work for me.
Can somebody confirm the anayevgv method is working ?
Or any other way to achieve that ?
Regards
Here’s my test code:
substitutions:
  device_name: ttgo-balance
  friendly_name: ttgo-balance
# Pinout définitions
  hx711_dout_pin: 'GPIO2'
  hx711_clk_pin: 'GPIO15'
esphome:
  friendly_name: ${friendly_name}
esp32:
  board: esp32dev
  framework:
    type: esp-idf
# Enable logging
logger:
  level: DEBUG
time:
  - platform: homeassistant
# Enable Home Assistant API
api:
  encryption:
    key: "xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx"
ota:
  - platform: esphome
    password: "xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx"
wifi:
  ssid: !secret wifi_ssid
  manual_ip:
    static_ip: !secret ip_ttgo-balance
    gateway: !secret wifi_gateway
    subnet: !secret wifi_subnet
  ap:
    ssid: "Ttgo-Balance Fallback Hotspot"
    password: "xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx"
captive_portal:
spi:
  clk_pin: GPIO18
  mosi_pin: GPIO19
#  DISPLAY  #
display:
  - platform: mipi_spi
    model: T-DISPLAY
    cs_pin: GPIO5
    dc_pin: GPIO16
    reset_pin: GPIO23
    rotation: 90°
    auto_clear_enabled: false
    update_interval: never
lvgl:
  displays:
    - my_display
  log_level: VERBOSE
  theme:
    label:
      text_color: 0x00ADEE
  pages:
    - id: weight_page
      bg_color: black
      widgets:
        - label:
            align: TOP_RIGHT
            text_font: montserrat_14
            text: "100"
        - label:
            align: CENTER
            text_font: montserrat_36
            text: "1200 gr"
#  OUTPUT  #
output:
# Display backlight
  - platform: ledc
    pin: GPIO4
light:
# ST7789V Display Backlight
  - platform: monochromatic
    output: st7789v_backlight_pwm
    name: "st7789v display Backlight"
    restore_mode: ALWAYS_ON
#  SENSORS  #
  - platform: hx711
    dout_pin: ${hx711_dout_pin}
    clk_pin: ${hx711_clk_pin}
    gain: 128
    update_interval: 10s
    filters:
      - calibrate_linear:
          - 863400 -> 0
          - 980000-> 4063
    unit_of_measurement: kg
    accuracy_decimals: 2
    on_value:
      then:
        - logger.log: "HX711 Weight changed"
        - lvgl.label.update:
            text:
              format: "%.1f gr"
              args: [id(hx711_weight).state]
              if_nan: "N/A"
select:
    options:
      - "0°"
      - "90°"
      - "180°"
      - "270°"
    optimistic: true
    on_value:
      then:
        - lambda: |-
            switch(i) {
        - logger.log: "Display rotation select changed"
#   WEB SERVER   #
web_server:
  version: 3
  port: 80
EDIT: It seems to be related with the mipi_spi component. if i switch back to the st7789v display platform It works.
Using the anayevgv method with the select or the luma method (with global, lambda set_rotation, …), if i use the esphome lambda display engine, my screen is rotating.
But problems, the st7789v will be removed, and with lvgl is marked FAILED: Memory allocation failure…
I’d like to be able to be able to rotate my screen with mipi_spi and lvgl, way easier to build ui and also future proof.
Do you think the problem is an syntax change needed, an omission in the mipi component or way more the way is it compiled ?
Rotation is handled by LVGL, not the display driver (even though you specify it in the display.)
Currently changing rotation at runtime isn’t supported though.
For thoose interessed in this topic, you can see the discussion here:
