Possible to install - ha-carson-living
Generally new to the platform but have been running Home Assistant OS under Proxmox which has been a great experience. I’ve been trying to add a custom camera feed from apartment building front door (in NYC and dealing with constant package theft with a very unresponsive build board is not great). The building uses an app called Carson Living which lets you have some basic functions (door buzz, access to camera feed, etc) but is a pretty terrible UI and not very responsive.
I discovered that someone else has already created an integration (GitHub - rado0x54/ha-carson-living: Home Assistant Component for Carson Living) but I’m having trouble figuring out how to get it installed with my existing setup. HACs custom repo allows me to add the integration but when I add the required login details to config.yaml it complains that Carson is not an installed integration. Very aware this is an issue with lack of knowledge on my part. Looking through the repo it looks like there are several dependencies (https://github.com/rado0x54/ha-carson-living/blob/b3be3f9608b60e4023829f7f055719f1c13cbcd8/requirements_tests.txt) so I’m sure this is also part of the problem. The integration looks a bit dated but the API version it uses with Carson is still the same so I’m sure the integration would function. Ideal world I can get this working with my existing install but I’m not sure if HAOS would allow it or if I would need to create a secondary HA install just to run this and possibly link it with the Remote-HomeAssistant component.
Large ask for a first time poster but very happy to finally join the community that has made this much possible so far. Looking forward to digging in and contributing as well.
You need to add the integration to HA, then restart HA so it can be loaded. Only then can you configure it.
Thanks @Tinkerer
I had tried that but still no luck until I saw that the manifest.json was missing a version number which blocked it. I updated that and now it’s loading which is great.
Next issue is I hit this error - it does seem to be much further along though! Could someone point me in the right direction? I believe I need to update the auth.py, specifically modify:
self._token_payload = jwt.decode(token, verify=False)
and update it to this:
self._token_payload = jwt.decode(token, algorithms=["ES256"], verify=False)
But I’m not sure if that’s possible.
Logger: custom_components.carson.config_flow
Source: custom_components/carson/config_flow.py:33
Integration: Carson
First occurred: 4:12:32 PM (5 occurrences)
Last logged: 4:36:20 PM
Unexpected exception
  File "/usr/local/lib/python3.11/site-packages/carson_living/auth.py", line 105, in token
  File "/usr/local/lib/python3.11/site-packages/jwt/api_jwt.py", line 210, in decode
    decoded = self.decode_complete(
  File "/usr/local/lib/python3.11/site-packages/jwt/api_jwt.py", line 147, in decode_complete
    raise DecodeError(
jwt.exceptions.DecodeError: It is required that you pass in a value for the "algorithms" argument when calling decode().
  File "/config/custom_components/carson/config_flow.py", line 56, in async_step_user
    token = await validate_input(self.hass, user_input)
  File "/config/custom_components/carson/config_flow.py", line 33, in validate_input
    await hass.async_add_executor_job(auth.update_token)
  File "/usr/local/lib/python3.11/concurrent/futures/thread.py", line 58, in run
  File "/usr/local/lib/python3.11/site-packages/carson_living/auth.py", line 137, in update_token
    self.token = data.get('token')
  File "/usr/local/lib/python3.11/site-packages/carson_living/auth.py", line 115, in token
    raise CarsonTokenError('Cannot decode invalid token {}'
carson_living.error.CarsonTokenError: Cannot decode invalid token xxxxxxxxxxxxxxxxxxxxxxxxxxxx
Just wanted to close this loop. I did some digging and the integration was dependent on PyJWT. It turns out that the verify=False parameter was depreciated versions ago… so it makes sense why this wasn’t working. I updated the parameter and now all is well!
Anyway - thanks for being a great community and look forward to diving in!
@justanz I am also trying to integrate that repo. Do you mind sharing the updated code?
Hi there.
To get this to work, you need to update line 105 in the auth.py file to read as follows:
self._token_payload = jwt.decode(token, options={"verify_signature": False})
All should work after that!
Can you add a link to the updated component files and your config.py? I have been struggling with the same issue
Did you end up getting it to work? Life has gotten in the way for me so haven’t being staying up to date here.
Since this isn’t being maintained I am a bit worried about what to do with these log warnings in the future and I’m not sure if anyone here has developed a solution.
SUPPORT_STREAM was used from carson, this is a deprecated constant which will be removed in HA Core 2025.1. Use CameraEntityFeature.STREAM instead, please report it to the author of the ‘carson’ custom integration
SUPPORT_OPEN was used from carson, this is a deprecated constant which will be removed in HA Core 2025.1. Use LockEntityFeature.OPEN instead, please report it to the author of the ‘carson’ custom integration
Justan, you have any basic steps on how to set this up, I downloaded in HACS, made the version fix, but then running into the same token problem. Stupid question but how do I get to to site packages, to edit the auth.py file, something about protected mode?
Took a bit since I have never made a custom component before but fixed up and cleaned up the depricated warnings.
Updated the readme instructions to make it clearer what to do also
works well thanks, none of my cameras appear in the entity listing. Any thoughts on a adjustments I need to make
