I’d like to generate YAML to show open doors on an ePaper display. It would be great to be able to iterate over my external door group and show the ones that are open without duplicating code for each door, and having to do more each time I add in another sensor. Is it possible at all? The way I’m trying to do it seems to be a non-starter:
service: open_epaper_link.drawcustom
entity_id:
- open_epaper_link.0000021BA6803B15
background: white
dry-run: true
payload: >-
{%- for openDoor in expand('binary_sensor.external_doors') | selectattr('state','eq','on') -%}
- type: text
value: {{openDoor.name}}
font: ppb.ttf
x: 0
y: 10
color: black
{% endfor %}
I have to say I don’t really understand when to use -, >-, |- but whatever I put at the top where payload starts results in an error, even if I take out the for loop.
Using a Jinja for loop to generate YAML can be a recipe for frustration. As you have set it up, the output isn’t interpreted as actual YAML, just a YAML-shaped string.
Since YAML is kind of a subset of json, and the template engine can output json objects, you should be able to use that to set your service data.
