If this question is better suited for the hardware category, please let me know.
Is it possible to bulk transfer my Zigbee devices from a Hubitat Elevation to a Home Assistant Yellow, or will I need to manually move them over one at a time?
I don’t think Hubitat can export your Zigbee network. Meaning of you were to move to something like ZHA or Z2M you’re doing it by hand.
But there is an integration you could use your Hubitat hub as your Zigbee coordinator and control it from HA? Unlike SmartThings, I think the Hubitat integration is local and you shouldn’t see significant lag using it that way.
That’s how I’ve been doing it up until now. I just figured I’d eventually want to switch everything over to my HA Yellow. I’m going to be getting some new Zigbee devices for the first time since getting my Yellow, so figured now might be a good time to see what the process would be like.
@NathanCu is correct. You have no option to export the devices. You are squarely in re-pairing territory.
