I run HA OS on a Odroid C2 and use the Skyconnect USB to manage some 8 sonoff sensors. Some sensors from upstairs intermittently break off and don’t send any data at all. Had to migrate my HA OS from RPi3 for better storage stability and ethernet speed.
I have an unused Elelabs shield and few old spare Raspberry Pi (2, 3 and zero w). I am trying to find out if it is possible to use these two as powered zigbee repeater.
Personally, I suggest buying either “IKEA Tradfri Signal Repeater ” or the “Aeotec Range Extender Zi” which are products that work very well out-of-the-box and work better than non-dedicated Zigbee Router devices, while a much more powerful alternative is to make yourself some semi-DIY variant by flashing the correct Zigbee Router firmware to Zigbee Coordinator USB dongles and then using them as stand-alone Zigbee Signal Repeater devices in USB-chargers for power, like, for example, either the Sonoff ZBDongle-E (EFR32MG21 based) or the Sonoff ZBDongle-P (CC2652P) work great as dedicated stand-alone Zigbee Signal Repeaters with recommended firmware. Or if you want to a support community members then check out TubesZB Zigbee Router/Repeater as discussed here.
