I purchase some ESP32-WROOM-32D DevKit C and I was wondering if it is possible to use one of them to open my garage door or rather trigger the garage door motor? That is, without buying additional hardware.
I don’t know this device, but usually the switch is momentary and shorts the terminals for a short time. This usually operates to open/stop/close in a cycle.
So yes an esp32 plus a relay can easily do this. You can also use a Reed switch to detect door position, or a tilt sensor.
I recommend you to look at esphome and in particular the cover components. Also take a look at opengarage.
Okay, I will setup my first DevKit and then order a relay.
Is there a noobie guide to starting with the ESP32? It seems the module does not have a WebUI to connect the device to my wifi. I can connect to the ESP32 wifi but cannot access any WebUI or anything.
I’m guessing I need to build an environment on my notebook just to hook up the ESP to my wifi so ESPHome can find it?
1 - lamp holder 24V 10W E14
2 - 24 V cable black
3 - 24 V cable black
5 - red motor cable
6 - motor cable green
7 - Fine fuse T 4A
8 - red LED
9 - CLOSED limit switch
10 - limit switch OPEN
11 - photocell
12 - 24 V ~ photocell
13 - learn button
14 - push button connection
its very simple and work great! i have more than 50 esp32 and WemosD1mini with Esphome, and work like a charm.
1-Install Add-on
2-go to the Add-on and check “Show in sidebar”
3-Go in side left bar of HA and click on EspHome
4-create a node and choose ESP32 wrover kit
5-Paste the sample config and change accordingly to your config :
Then validate to check if you make some syntax errors, then “install” and “manual download” only the first time, after you can made “OTA update”, no need to plug the ESP32 to your PC or RPI
you have several version, i use the windows version.
Check the USB port when you plug your ESP32 in the peripheral manager in windows,
then select the port in EspHome flasher and the file you just download.
Then after flashing your node will be ready and you will have a new node discovered in HA, just accept and you will have a switch sensor to open you gate remotely.
I add the status wifi, to check in HA if your node is online or not, and another “switch” to restart your node if something wrong happen.
Perfect, thank you very much for the step by step!
Now if only I could connect via https.
Firefox gives me “SSL_ERROR_RX_RECORD_TOO_LONG”.
Chrome gives me “ERR_SSL_PROTOCOL_ERROR”.
I’ followed some instructions that said I needed DuckDNS (even though I do not need, want or can even use a DNS service behing DS-Lite) and after installing I have lost access to my HA setup so had to manually remove the entries in the configuration.yaml -.-
Now I just need to find out how to enable https access.
Okay, so now all three of my ESP32 devkits are online and connected to HA.
I will open a dedicated thread to getting it setup properly first (currently MQTT is not showing in HA and I would like to be able to send commands via Bluetooth as well).
Once they are setup properly, I would come back here and try to figure the garage door opener out. I would like to try without adding a relay module first. If that fails, I would opt for an additional module.
