I would like to send some data from my own PHP code on Debian cloud server to the Home Assistant (with supervisor) running on raspberry pi with Home Assistant OS.
The suitable option for me seems to be webhooks - update input_text object via webhook is more than enough for me, I can then create automations based on this input_text and my custom strings
I spend 48 hours searching and reading about it and yet I can’t figure out what I am doing wrong. Could you please look and my code? maybe someone here can help me Do you know any troubleshooting steps/software I could try to identify what am I doing wrong?
Let me know if I should post more information here.
Thanks in advance!
php file posting to webhook API - using curl
// where are we posting to?
$url = "https://%MYURL%/api/webhook/m6status";
// what post fields?
$fields = array(
'field1' => "test1",
'field2' => "test2",
'text' => "axasxasx"
// build the urlencoded data
$postvars = http_build_query($fields);
// open connection
$ch = curl_init();
// set the url, number of POST vars, POST data
curl_setopt($ch, CURLOPT_URL, $url);
curl_setopt($ch, CURLOPT_POST, count($fields));
curl_setopt($ch, CURLOPT_POSTFIELDS, $postvars);
// execute post
$result = curl_exec($ch);
echo $result; // I always got 1 - as successfull
// close connection
curl_close($ch);
configuration.yaml
input_text:
mazdastatus:
initial: nothing
automations.yaml
- id: 'xxxxxxxxxxxxxx'
alias: 'webhook mazda status '
description: ''
- platform: webhook
webhook_id: m6status
condition: []
- service: input_text.set_value
value_template: '{{ trigger.data.text }}'
entity_id: input_text.mazdastatus
mode: single
errors from log:
While executing automation automation.webhook_mazda_status
14:49:14 – Automatizácia (ERROR) - správa sa prvýkrát vyskytla o 14:49:00 a opakuje sa 2 krát
webhook mazda status : Error executing script. Invalid data for call_service at pos 1: extra keys not allowed @ data['value_template']
