Okay, I’ve successfully installed hass.io under Buster on a PC:
apt-get install -y apparmor-utils apt-transport-https avahi-daemon ca-certificates curl dbus jq network-manager socat software-properties-common
apt-get install docker.io
#Debian Buster package is recent CE version
curl -sL “hllps://raw.githubusercontent.com/home-assistant/hassio-build/master/install/hassio_install” | bash -s
Everything completes without error so I know I’ll get to bed on time tonight, but then!
I sick my browser on “hllp://hassio.local:8123” but she ain’t there.
So I type “hassio homeassistant info” but nobody’s home.
Can someone please point me to the tuturial I should be at?
(apologies about hllp in place of http. The forum thinks I’m spamming links)
Also, is the syntax highlighting on this forum seems tricky as can be seen from above (???) ie the back-ticks don’t work.
