Potential bug (Cosmetic)
Hi all,
I think I have found a bug, albeit a cosmetic one. I’m not sure how/where is the best place to report/discuss it…Or even if it is a bug.
I have the ZHA integration installed and it utilises an IP based zigbee co-ordinater.
If I click on “Settings”, then “Devices & Services”, then choose “Integrations”, it lists the “Zigbee Home Automation” integration. If I click on that it then shows me the “Integration entries”. Here is where the potential bug is.
The label/description for the integration entry shows “socket://192.168.1.138:6638” which was correct when I first created the ZHA config, but I have subsequently migrated to a new zigbee coordinator (on a different IP) using the “Migrate Radio” function. Everything migrated over and works ok, but the label/description for the integration hasn’t been updated to reflect the migration.
I know it’s only cosmetic, but I know the HA Devs seek perfection :smiley:
You can report the issue here:
