Potential Homeseer to HA convert queries
Hi all,
I’ve been using Homeseer for 10 years or so now and I have to say while HA was not quite ready when I first thought about moving, it certainly feels like it is now to make the jump.
Could I ask a few quick queries which some may just be yes/no responses?
  1. The first is around hosting. Ever since my first hardware failure with Fibaro, I’ve always wanted to ensure I can lift and shift easily should I have another failure. This is very easy with Homeseer but I’ve still used it on a VM so it is even easier.
I’ve installed a test setup of HA yesterday on VirtualBox as I feel this is the simplest method to run on a Windows Server machine.
a. If the PC suddenly dies, can I simply move the disk image to another PC running VirtualBox and I’m up and running? (obviously ensuring network/usb settings are correct etc)?
b. Is VB ok to run HA under within a Windows Server environment?
c. Should I go Proxmox / HA instead for long-term?
  1. I’m currently using a Aeostick 5 Plus but just waiting on a Aeostick 7 to deliver today and the view is to essentially start again with all my devices. I assume this stick is perfectly fine and stable to use with z-wave and HA?
  2. The PC in question has 16GB Ram - again is VB/HA ok to run if I assign it say 8GB to the VM? It’s an i5-6500 HP Elitedesk mini.
    Essentially I have two of these hence the previous query about lift and shift.
Thanks in advance!
AJ
If your installation is dependent on MQTT know that the instructions all over the internet that make it look like it’s just an add-on of some kind are referencing past functionality that’s no longer included in the product. mosquitto_broker is turning out to be more of a project than I wanted, and I committed to HA based on thinking I might have that functionality in a docker image. You will not without extensive manual configuration. And I’m not joe schmo who’s never seen Linux before 2025, I’m a former RHCSA who doesn’t see any value in recertifying so soon.
Sorry what does this refer to?
MQTT and mosquitto broker are an integration you’ll need working to make a lot of sensors work properly. They report in via message queue. HA had a working integration but they deprecated it.
As far as I know, nothing to do with my query.
I can see you’ve been on MQTT threads today so maybe you are confused? I’m not even a HA user per se as of yet hence my queries.
That would be my preference compared to running it in VirtualBox on Windows.
FWIW, I have been running Home Assistant Supervised on Debian for several years now (on what is now a ~14 year old Dell laptop). No complaints other than the rigmarole of periodically upgrading Debian (version 10, 11, and now 12).
The next upgrade will probably be to a mini pc with Proxmox and Home Assistant OS.
I can’t speak from experience but the documentation indicates that device is supported.
Yes, and I’m a new HA user installing on docker but you’ll run into the same issue I’ve got when you try to configure anything that phones in via MQTT. You’re looking at the issue from a mile high macro view of the server OS and virtualization, and I’m trying to advise you of a micro level problem that’s potentially a huge headache that you’ll have to get through. You may or may not need it, but 40% of installations use it and it’s not straightforward to get working.
But you’ve already dismissed me since I’m also new and currently working through a problem, and that’s fine. Later!
Yes
If you have no other option, it works
Proxmox is a great choice
Yes:
If you are just starting out, we recommend that you purchase a 700 series controller (with firmware updated to >=7.17.2).
https://www.home-assistant.io/docs/z-wave/controllers/#supported-z-wave-usb-sticks--hardware-modules
Yes, for starting that’s quite enough. Depending on what you do with HA you may outgrow that. If that happens it’s easy to migrate to better hardware.
Welcome! There are several threads in these forums about migration from Homeseer to HA - be sure to search for them. I’ve never regretted making the jump several years ago.
FYI
If you choose either of the following two installation methods, it will be straightforward to install and configure an MQTT client and broker (if you need it):
  • Home Assistant OS
  • Home Assistant Supervised
The recommended choice is Home Assistant OS.
  • The MQTT client portion is provided by the MQTT integration.
  • The MQTT broker portion is provided by MQTT Broker Add-on.
The other two installation methods are:
  • Home Assistant Container (pure Docker-based version)
  • Home Assistant Core (python-only version)
Both Container and Core are considered to be advanced installation methods and assume the installer is familiar with the additional knowledge and administration required.
They support the MQTT integration (which allows Home Assistant to be an MQTT client). However, neither supports any Add-ons so you don’t have the ability to conveniently install an MQTT broker (like in OS and Supervised). That task is left up to you, including configuration to permit the client (Home Assistant) to login to the broker. It’s this step that tends to be challenging (but is trivial if you’re using OS/Supervised with the MQTT Broker Add-on).
AJ, I used HomeSeer for nearly 20 years before moving to Home Assistant. I started by running VirtualBox on the Windows machine that ran HomeSeer for nearly a year. I also ran a second instance in VirtualBox on my personal workstation as a “dev” instance. No issues with that method here.
Yes. I’ve done that between the 2 instances I mentioned above.
I’m now running both Prod and Dev instances on 2 Proxmox nodes in High Availability. The VM snapshot and backup options in Proxmox make managing HA operations and upgrades much easier, IMHO.
Same hardware specs for my HomeSeer Windows machine. I never gave the Home Assistant VM more than 4GB of memory and never had a problem with the collections of Add-ons I choose to run.
Good luck with your migration if you choose to make it. I can easily say I don’t regret the change at all. There is a learning curve to understand the architecture and patterns that work well in Home Assistant. Don’t make the mistake of trying to simply convert HS automation logic to HA automation logic. They don’t compare.
There are tons of resources on the forums but be careful to check post timelines. Home Assistant has changed significantly in the short 2 years I’ve used it. Check any advice against current documentation. The documentation is much better than HS, again IMHO.
Brilliant thank you all for your responses.
@Tinkerer Where possible, I’ll be updating the firmwares so no issue there. The Z-stick 7 has in fact just arrived. I noticed on the Aoetec site, they have instructions on how to pair the z-stick up to HA.
I did also however find a HA article to avoid the EU version due to performance issues - is this still an issue given mine would be EU being in the UK?
PecosKidd Thanks! I’m probably treating this as starting from scratch albeit with devices already included and so I’ll exclude/include but nothing is being “migrated” from HS in this case.
@123 I have to say this is the bit that confuses me about the whole MQTT. And maybe this is where I apologise to tekno-yanqui as I had no idea what the relationship was with MQTT and HA.
Either way, my understanding is the fact I’ve chosen to go via Proxmox or VirtualBox means I am going down the Home Assistant OS route albeit on a VM.
Thank you @mterry63 - for some reason, I seem to recognise your name from HS days - maybe a Goodbye HS, Hello HA type thread? - maybe I’m just imagining things
I’m going to try and get Proxmox installed along with HA tonight on the machine and see how that goes leaving the current VB version as is on my laptop as a Dev system.
I was thinking a parallel install but I’ve got enough corruption currently that I either “reset” both HS and get HA in or just concentrate on one - I think I’ll go for HA knowing if it all goes pear shaped, I’m skilled enough with HS to spin up a new VM and get going.
re spec, I suppose I could either give it the 8GB or so or start at 4GB and upsize if needed. I’m looking around my spares to see if I can find any 16GB modules as I think it can handle 32GB in which case I can future-proof and assign more now.
As for HS logic - agreed and I think I’m finding this more and more that there are tons of articles that are old and outdated. Is there a general rule of thumb? ie last 6-12 months are ok?
The biggest events stack I have in HS are around motion sensors switching on lights, off after x mins if no motion and also if the manual switch is flicked on/off/on, it temp disables the auto-off from no motion (long bath for instance where not much movement)
Other than that, I have nothing complex that HA could not do for me I don’t think.
I’m feeling more comfortable with your history of 20 years with HS and yet being happy with HA that I don’t feel I need to ‘test’ the z-wave but go straight into building a prod environment. Don’t worry I won’t hold you accountable if it does not work:- )
100% agree.
@skykit
Compared to common scripting languages, what Home Assistant uses can be perplexing on first glance.
It uses a combination of two other open-source software projects: YAML and Jinja2.
YAML is a markup language (typically used for defining configurations) and Jinja2 is a templating language (with python-like syntax).
Think of YAML being used to create a form with fields and Jinja2 used to (optionally) compute values for those fields.
alias: example automation
description: Report which door opened but only during the night.
triggers:
  - trigger: state
    entity_id:
      - binary_sensor.front_door
      - binary_sensor.rear_door
      - binary_sensor.garage_door
    to: 'on'
conditions:
  - condition: state
    entity_id: sun.sun
    state: below_horizon
actions:
  - action: notify.persistent_notification
       message: "The {{ trigger.to.state.name }} just opened."
Initially, use the Automation Editor in Visual mode and then switch it to YAML mode to see the code it automatically generated. Continue working this way and eventually you will become comfortable with the code’s structure.
At some future date, you may wish to compose the automation entirely in YAML mode because Visual mode doesn’t currently expose all of Home Assistant’s available automation features (most, but not all).
BTW, to share an automation, you just copy an example from the forum and paste it into the Automation Editor while it’s in YAML mode.
FWIW, more advanced users avoid the Automation Editor entirely and compose their automations with a text editor like VS Code (with some plugins).
Yes, I did one of those.
6 months should be good, 12 months you may have to validate or expect to do some minor mods. Most recently the so-called “service-call” command was changed to “action” but both are acceptable at the moment (I believe). the HA Devs do give a clear timeline for depreciating old ways of doing things.
You’ll have to get used to the scheduled updates cycle of HA. It moves along at a quick pace, which can be a double-edge sword. At least you don’t have to upgrade.
For Z-wave, some advice - Start with the Z-wave-JS UI add-on, not the “core” (HA developed and maintained) add-on. You’ll appreciate the extra features. I moved my Z-wave network between platforms without change, just moved the controller from one system to the other “as-is”. No issues with that.
MQTT is another protocol available to Home Assistant which can help connect other technologies/devices. If you don’t use it now (sounds like you don’t) you can visit it at your leisure. I had a MQTT integration and broker in use with HomeSeer (Tasmota devices), so I just kept the broker as-is and moved them to Home Assistant. The great thing is there are hundreds if not thousands of integrations that are all free, not a per integration cost like HomeSeer.
Again, best of luck and welcome to the forum!
I am in the HAOS in Proxmox camp.
I recently went from HAOS on ESXi to Proxmox. The switch was so darn easy. A backup from HAOS was used in the new install in Proxmox and was a breeze.
You only need it if you intend to have Home Assistant communicate with any devices you have (or other systems) that support MQTT. For example, I still use my former home automation software (trusty old Premise) in addition to Home Assistant. The two communicate via MQTT (Premise supports some legacy devices I have for which there are no integrations in Home Assistant).
The questions in your first post didn’t mention MQTT, so having it introduced unsolicited in a reply was understandably puzzling. Just know that its installation and configuration is easier if you use the recommended Home Assistant OS installation method.
Read the thread I posted, there’s a guide at the end of it someone shared. I marked it as the solution.
Join the HA Discord and ask the Z-Wave gurus over in the #related-tech channel - I switched fully to Zigbee a while back and haven’t kept fully on top of what’s going on in the Z-Wave world.
@skykit
Be advised those instructions aren’t needed (and don’t apply) if you install the MQTT Broker Add-on on Home Assistant OS (or Home Assistant Supervised).
