In Home Assistant, the full energy equation for generators and consumers is
Solar + Import + Discharge = Consumption + Export + Charge
and HA solves this for the House Consumption Energy as
Consumption = Solar + (Import - Export) + (Discharge - Charge)
and if we know for any given period the five right-hand variables, HA can work out the consumption energy.
In terms of power, as the instantaneous rate of energy use, the Energy Dashboard works out much the same equation. Since the Grid can be either importing or exporting, but not both at the same time, and if you have a battery in the mix, the battery can be discharging or charging but again not both, HA uses
Load = Solar + Grid + Battery
where Grid = Import - Export, and Battery = Discharge - Charge if you have separate import/export and discharge/charge power sensors
In this Solar will always be positive, Grid and Battery will be positive for import/discharge towards the home, and negative for export/charge away from the home.
Since you don’t have a battery, the Power Equation for you reduces to
Load = Solar + Grid
Your Solar power sensor looks OK. The graph, as it is, indicates that you are not exporting anything, and Grid is zero all the time that solar power >= load.
Unlike the Energy settings, where we have two sensors, one for the energy imported from the grid [Grid consumption], and one for the energy exported to the grid [Return to grid] (and in your case you have two of each with different tariffs) the Power sensor setting normally has only one sensor. This has to show a +ve figure when importing power, and a -ve figure when exporting power.
For most of us, I think that our inverter / meter integration starts with just the basic power value, that shows as +/- depending on direction, and is exactly what the dashboard requires. This single sensor then has to be separated into power-in / power-out and then to energy-in / energy-out for the two energy sensors. If you only have one power in sensor and another power out sensor, then either they need to be combined [template sensor], or the second could be added to the Grid power sensor list, but note that the power out must be a negative value.
Hope that helps!
