Power consumption plugs or?
Hello
I use some plugs that are flashed with tasmoto and they work perfectly, until I try to use them to control the home automation stuff, i.e. the server running HA. If I reboot the system the sockets reboot and then restart and then argh never turn on till HA/MQTT is running… so a deadlock. Can someone recommend some plugs or clip on electricity monitoring things please? just so I can check on my phone as to how much a device costs to run?
Cheers
Mark
I would check your settings in tasmota as to why they are turning on/off with broker disconnects. They should keep their states.
Also look into the retain settings. I have a number of tasmota devices that don’t flinch when the system comes down.
ok cheers… most of my tasmota devices flick on/off or just off with a ha reboot… will check that thanks
I’ve tried for ages to get this sorted. Still the same, as soon as HA reboots the switches power off
followed this and still the same
09:27:34 MQT: Attempting connection...
09:27:39 MQT: Connect failed to 192.168.0.102:1883, rc -2. Retry in 10 sec
09:27:50 MQT: Attempting connection...
09:27:55 MQT: Connect failed to 192.168.0.102:1883, rc -2. Retry in 10 sec
09:28:06 MQT: Attempting connection...
09:28:11 MQT: Connect failed to 192.168.0.102:1883, rc -2. Retry in 10 sec
09:28:22 MQT: Attempting connection...
09:28:27 MQT: Connect failed to 192.168.0.102:1883, rc -2. Retry in 10 sec
09:28:37 MQT: Attempting connection...
09:28:42 MQT: Connect failed to 192.168.0.102:1883, rc -2. Retry in 10 sec
09:28:53 MQT: Attempting connection...
09:28:58 MQT: Connect failed to 192.168.0.102:1883, rc -2. Retry in 10 sec
09:29:09 MQT: Attempting connection...
09:29:14 MQT: Connect failed to 192.168.0.102:1883, rc -2. Retry in 10 sec
09:29:25 MQT: Attempting connection...
09:29:30 MQT: Connect failed to 192.168.0.102:1883, rc -2. Retry in 10 sec
09:29:33 RSL: tele/homeassistant/STATE = {"Time":"2020-02-06T09:29:33","Epoch":1580977773,"Uptime":"0T00:07:03","UptimeSec":423,"Heap":21,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":35,"POWER":"ON","Wifi":{"AP":1,"SSId":"RenHome","BSSId":"B6:B9:8A:4C:8A:00","Channel":6,"RSSI":34,"LinkCount":1,"Downtime":"0T00:00:08"}}
09:29:33 RSL: tele/homeassistant/SENSOR = {"Time":"2020-02-06T09:29:33","Epoch":1580977773,"ENERGY":{"TotalStartTime":"2019-07-21T20:07:39","Total":43.090,"Yesterday":0.000,"Today":0.334,"Period":2,"Power":14,"ApparentPower":30,"ReactivePower":27,"Factor":0.47,"Voltage":245,"Current":0.123}}
09:29:41 MQT: Attempting connection...
09:29:46 MQT: Connect failed to 192.168.0.102:1883, rc -2. Retry in 10 sec
09:29:56 MQT: Attempting connection...
09:29:56 MQT: Connected
09:29:56 MQT: tele/homeassistant/LWT = Online (retained)
09:29:56 MQT: cmnd/homeassistant/POWER =
09:29:56 MQT: tele/homeassistant/INFO1 = {"Module":"BlitzWolf SHP","Version":"6.6.0.2(ce13c0c-sonoff)","FallbackTopic":"cmnd/DVES_272999_fb/","GroupTopic":"sonoffs"}
09:29:56 MQT: tele/homeassistant/INFO2 = {"WebServerMode":"Admin","Hostname":"homeassistant-2457","IPAddress":"192.168.0.7"}
09:29:56 MQT: tele/homeassistant/INFO3 = {"RestartReason":"Power on"}
09:29:56 MQT: stat/homeassistant/RESULT = {"POWER":"ON"}
09:29:56 MQT: stat/homeassistant/POWER = ON
09:29:57 MQT: stat/homeassistant/RESULT = {"POWER":"OFF"}
09:29:57 MQT: stat/homeassistant/POWER = OFF
I have about a dozen Innr SP 120.
I use ESPHome for my power monitoring plugs and also faced this issue.
The ‘workaround’ I used was defining an increased reboot timeout in the native api section
Not sure if there is something similar for tasmota?
Can you read total consumption from SP 120?
I think it is just on and off…
It creates a power sensor and a consumption sensor in deCONZ at least.
I mean they are created in HA if you use deCONZ.
Unfortunately I have no deCONZ, I use Aeotec stick and ZHA.
ZHA creates:
_electrical_measurement - shows current power
_on_off
_smartenergy_metering - shows “Unknown”, I suppose this must be “consumption” value?
sp 120 shows current consumption (along with V and A) and total consumption.
Thanks… I stand corrected.
