Hi, does anyone have any idea why on my old iPad Air in the “power-flow-card plus” view on the dashboard everything is only displayed as code and not visually. On a newer iPad it works fine.
Probably best to ask the card developer. There’s a forum topic for it.
Can you help me and tell me where it is posted correctly
The forum has a search function. It’s the first result: Search results for 'Power flow plus card' - Home Assistant Community
Thank you very much!
What OS is the iPad running? Are you using the HA Companion app for iOS or viewing in Safari/WebKit?
I´m using the app and the iOS Version is 12.5.7.
However it is the same on this device in Safari and in the app.
+1 … I too am experiencing the same issue on an old iPad Air using the HA app. Block of code is displayed instead of the diagram. I’m suspecting the iPad is a bit… past it’s prime, but thought I’d bump this thread just in case there’s another solution.
Ask the developer at the link provided above.
