Hey there!
I’ve got a Shelly Plug S with Tasmota that I’ve connected to our coffee maker. I want to get the time it took to boil the water, so that I can calculate in the automation when the coffee will be finished.
This is how a usual usage graph looks:
At the beginning the water is boling (> 1000 W), after that the heater for the coffeepot is on (~55 W).
I’ve created an automation with a trigger that triggers when the power comsumption is between 40-70 W:
alias: Kaffeemaschine ausschalten
- type: power
platform: device
device_id: c9e9e062cf754dfff249ce97da2b4fb7
entity_id: sensor.shelly_plug_s_energy_power
domain: sensor
below: 70
above: 40
I’ve tried using a template sensor which tracks the different states (water boiling, heating and off) and a history stats sensor, but you unfortunately with this method you have to define a time span and it wouldn’t work correctly if I use the coffee maker more than once in the defined time span.
I also tried to use the trigger.for
Automation Trigger Variable in the action:
of the automation, but in my example the value was None
In the automation I need to get the duration of the last time the power consumption was above 1000 W. What’s the best way to achieve this?
