HI i just connected my home assistant to homey with mqtt i need how to integrate energy meter vaule into a energy dashboard .In the Grid consumption list dont show the energy meter device entity . there is a solution to this problem ? I thought a virtual device with the given values should be set up ?
entity : sensor.elektromer_power
Device settings can be modified
Hi, the energy dashboard tracks Energy in kWh not Power in W, you either need to obtain the energy value from your meter or else calculate this in HA using an integration function as below (this actually includes an example of what you need):
