Hi comrades.
can you advice, please, how to integrate serial sensor/meter (pzem-004t). Normally it shall be a message of special format sent to /dev/ttyUSB0 periodically. Certain bytes in feedback/msg shall be used to evaluate result.
Which configuration primitive should be used to define command format and feedback/translation algorithm?
import serial
from binascii import unhexlify
import sys
port = "/dev/ttyUSB0"
baud = 9600
if (len(sys.argv)<=1):
sys.exit()
is_voltage=False
is_current=False
is_active=False
is_energy=False
for arg in sys.argv:
if (arg=="voltage"):
is_voltage=True
elif (arg=="current"):
is_current=True
elif (arg=="active"):
is_active=True
elif (arg=="energy"):
is_energy=True
ser = serial.Serial(port, baud, timeout=1)
# open the serial port
if ser.isOpen():
voltage_str = "B0C0A80101001A"
current_str = "B1C0A80101001B"
active_str = "B2C0A80101001C"
energy_str = "B3C0A80101001D"
if (is_voltage):
ser.write(unhexlify(voltage_str))
out = ser.readall()
print (out[1]*256+out[2] + out[3]*0.1)
if (is_current):
ser.write(unhexlify(current_str))
out = ser.readall()
print (out[2] + out[3]*0.01)
if (is_active):
ser.write(unhexlify(active_str))
out = ser.readall()
print (out[1]*256+out[2])
if (is_energy):
ser.write(unhexlify(energy_str))
out = ser.readall()
print (out[1]*256*256+out[2]*256+out[3])
ser.close()
add following items to /config/configuration.yaml
pzem004:
sensor pzem004-current:
- platform: command_line
command: python3 script_power_meter.py current
unit_of_measurement: "A"
sensor pzem004-voltage:
command: python3 script_power_meter.py voltage
unit_of_measurement: "V"
reboot and add new sensors “pzem004-voltage” and “pzem004-current” on home assistant web page
Hi, l know that there are 2 versions of Pzem004: the oldest with normal serial communication and the newest v.3 that use modbus protocol. Wich version are you using?
Did you use a serial ttl to usb converter?
Ok, thank you. I have the new version PZEM 004 v.3 modbus (not yet used) Pzem-004T.v3.0 and i’m wondering 2 questions (i’m new on raspberry and in programming):
is it possible to connect the new PZEM modbus version to Raspberry (using an usb dongle) and simply use HA modbus integration (https://www.home-assistant.io/integrations/modbus/) without any extra code?
if point 1 is feasible, is it possible to connect several PZEM modbus to only one USB dongle? I should connect 6-9 of them to my HA to check a three phase system…
I’ve a question on how you connect the reference wires to live and neutral on the pzem-016… I was thinking I’d just take the live and neutral from a power socket next to my utility board… or do I specifically have to take the live from before all the loads and the neutral from after all the loads?
