Power outage fun
Good afternoon:
Had the first power outage since I got all my HA stuff up and running and, now that power is back on, Zigbee2MQTT is giving me the “502: Bad Gateway” error when I try to open the UI. Looked at the logs and noticed it’s failing to start…
Looked over the “Zigbee2MQTT fails to start” link referenced in the error and, while trying to verify the port in the configuration.yaml file, I noticed that /dev/serial is flat out gone…it’s just not there anymore…
…and that is where it was before…
Anyone else had this happen? I’m going to try shutting down the entire HA VM, unplugging the little USB dongle thing, starting the VM, then plugging it back in (and various permutations of this procedure) to see if maybe it’s just not being recognized or something, but I don’t know. First time dealing with all this.
Any info and thoughts greatly appreciated!!
Thanks!!
Did you figure this out. just happened to me today. AT my whit’s end…
