The only power metering plug for Switzerland that I used is the myStrom one and it’s way too expensive (as everything over here like the Xiaomi door sensors, 25 CHF really? I got 15 of them from gearbest for 100 CHF incl. shipping).
I just don’t trust this Aliexpress stuff for anything mains powered.
I hope that I’m wrong, but it looks like the situation did not improve in 2022 when checking CH Devices. It’s either “you need to calibrate” or “open the switch and fiddle with it”. In the end I don’t even care about Tasmota. Is there really no CH plug with power metering that works halfway reliably with HA?
I’m looking for the same thing, for some time now, and with no luck.
I was able to find something on Aliexpress, Zigbee smart plug CH, but apparently it’s a scam seller, as after almost 2months it still wasn’t shipped so I was refunded.
I gave up on Zigbee, now I’m trying to find something with MQTT, as I don’t want to use some wifi device with dedicated app.
Update:
So finally I was able to find CH Zigbee plugs, with and without power monitoring, on AliExpress of course. Price is decent, delivery was fast and they work flawlessly.
If anybody else needs swiss (or other) Zigbee plugs I can only recommend these ones.
I recommend checking out the “ATHOM global store” (https://athom.aliexpress.com/store/) on Ali. Sometimes they have swiss tasmota smart plugs. Was lucky enough to buy one tasmota pre flashed for 12chf. But now they’re gone
Maybe they’ll come back in some time.
Hello, yes we will also add Zigbee Swiss wall plugs if the tests are positive. If you want, please feel free to send an email to our support and we will contact you when ready.
Thanks man, I was looking so hard for a ZigBee power monitoring plug and the one you linked worked perfectly with Z2M! Thanks a bunch! @SwissDomotique Would it be possible you add those to your store too? Thanks for considering!
