Power sensing issues
Hi everyone!
I have a simple light control / dimmer circuit, with ESP32 and MOSFETs that controls 12 or 24V LED lights. It’s built into light fixture and beside using the “smart” way of switching the light on/off via app I wanted to keep the wall switch function. The switch detection circuit senses the voltage on the live wire from wall switch (230V AC/50Hz), limits the current, rectifies it and switches an optocoupler, from which the output connects to ESP32 GPIO.
Everything works as intended 99% of the time. Except… And here comes my problem: every day the light turns on without any reason couple of times. It seems like some voltage spike or some HF interference makes the AC detection circuit to switch on.
In older version of YAML I used a simple binary_sensor with delayed_off filter:
binary_sensor:
  - platform: gpio
    pin:
      number: GPIO13
      mode:
        input: true
        pullup: true
      inverted: True
    name: "Power sense 1"
    internal: True
    filters:
      - delayed_off: 50ms
    on_state:
      then:
        - if:
            condition:
              - binary_sensor.is_on: power_sense_1
            then:
               - script.stop: timer_off
               - light.turn_on:
                   brightness: 100%
I tried to increase the delay in filter up to 500ms, it didn’t help.
I thought the filter might have some bug, so I came with different, quite complicated approach. I’m checking the state of the power_sense GPIO every 5ms and if it’s ON, I increase the counter value (global variable). And every 30ms the value is decreased no matter what. When the counter reaches value of 100, the light is turned on.
The problem remains, the light turns on 3-5 times during the night. What’s interesting, it almost never happens during the day. It happens between 18:00 - 23:00 and then again early in the morning 5:00 - 8:00.
My suspicion was some other appliance might interfere, like well pump, but I am monitoring its cycle and it doesn’t match.
I have 3 of these dimmer circuits on different places, they all have this random turn on problem, but their times are different.
Does anyone have any clue, what causes these random turn-ons? Or what would be the best way to sense the wall switch state?
The circuit diagram is here, please ignore the triac dimmer part, it’s not used, the parts aren’t even on PCB.
And here’s the complete YAML:
esphome:
  friendly_name: RGBCCW Dimmer
substitutions:
  devicename: RGBCCW Dimmer
esp32:
  board: esp32dev
  framework:
    type: arduino
# Enable logging
logger:
# Enable Home Assistant API
api:
  encryption:
    key: "xxxxxxxxxxxxxxxxxxxxx"
ota:
  - platform: esphome
    password: "xxxxxxxxxxxxxxxxxx"
wifi:
  ssid: !secret wifi_ssid
  ap:
    ssid: "Rgbccw-Dimmer Fallback Hotspot"
    password: "xxxxxxxxxxxx"
captive_portal:
globals:
  - id: ps_on_1
    type: int
    restore_value: False
    initial_value: "0"
  - id: light_on_1
    type: int
    initial_value: "0"
  - id: ps_on_2
    type: int
    initial_value: "0"
  - id: light_on_2
    type: int
    initial_value: "0"
  - id: counter_on
    type: int
    restore_value: false
    initial_value: "0"
# D16, D17 - relays
# D13 - power sense from wall switch
# D25, D26 - PWC outputs
# D23 - One wire
# D2 - builtin LED
# D33, D32 - free GPIOs
output:
  - platform: ledc
    pin: GPIO27
    frequency: 9765Hz
  - platform: ledc
    pin: GPIO26
    frequency: 9765Hz
  - platform: ledc
    pin: GPIO25
    frequency: 9765Hz
  - platform: ledc
    pin: GPIO33
    frequency: 9765Hz
  - platform: ledc
    pin: GPIO32
    frequency: 9765Hz
  - platform: ledc
    pin: GPIO23
    frequency: 9765Hz
  - platform: ledc
    pin: GPIO22
    frequency: 9765Hz
light:
  - platform: rgbww
    name: "RGBWW LED Strip"
    red: ledc_output_r
    green: ledc_output_g
    blue: ledc_output_b
    cold_white: ledc_output_c
    warm_white: ledc_output_w
    cold_white_color_temperature: 6536 K
    warm_white_color_temperature: 2000 K
    gamma_correct: 1.0
    default_transition_length: 2s
  - platform: monochromatic
    output: ledc_output_mono1
    name: "White LED 1"
    gamma_correct: 1.2
    restore_mode: RESTORE_DEFAULT_OFF
    output: ledc_output_mono2
    name: "White LED 2"
    gamma_correct: 1.5
status_led:
  pin:
    number: GPIO2
button:
  - platform: restart
    on_press:
      - light.dim_relative:
          relative_brightness: 1%
    on_press:
          relative_brightness: -1%
interval:
  - interval: 5ms
    then:
      - if:
          condition:
          then:
            - lambda: |-
                if (id(ps_on_1) < 105) {
                  id(ps_on_1)++;
                id(counter_on)++;
            - if:
                all:
                  - lambda: |-
                      return (id(ps_on_1) > 100);
                  - lambda: |-
                      return (id(light_on_1) == 0);
                then:
                  - lambda: 'id(light_on_1) = 1;'
                  - script.stop: timer1_off
                  - light.turn_on:
                      brightness: 100%
      - if:
          condition:
            - binary_sensor.is_on: power_sense_2
          then:
            - lambda: |-
                if (id(ps_on_2) < 105) {
                  id(ps_on_2)++;
            - if:
                all:
                  - lambda: |-
                      return (id(ps_on_2) > 100);
                  - lambda: 'return id(light_on_2) == 0;'
                then:
                  - lambda: 'id(light_on_2) = 1;'
                  - script.stop: timer2_off
                  - light.turn_on:
                      brightness: 100%
  - interval: 30ms
    then:
      - if:
          condition:
            lambda: |-
              return (id(ps_on_1) > 0);
          then:
            - lambda: |-
                id(ps_on_1)--;
            - if:
                condition:
                  lambda: |-
                    return(id(ps_on_1) == 0);
                then:
                  - script.execute: timer1_off
      - if:
          condition:
            lambda: |-
              return (id(ps_on_2) > 0);
          then:
            - lambda: |-
                id(ps_on_2)--;
            - if:
                condition:
                  lambda: |-
                    return(id(ps_on_2) == 0);
                then:
                  - script.execute: timer2_off
binary_sensor:
  - platform: gpio
    pin:
      number: GPIO13
      mode:
        input: true
        pullup: true
      inverted: true
    internal: true
  - platform: gpio
    pin:
      number: GPIO14
      mode:
        input: true
        pullup: true
      inverted: true
    name: "Power sense 2"
    internal: true
one_wire:
  - platform: gpio
    pin: GPIO5
  - platform: dallas_temp
    address: 0x330218606459ff28
    name: "Board temperature"
    update_interval: 60s
    address: 0x4100000084eb3a28
    name: "External sensor temperature"
    update_interval: 10s
    lambda: |-
      return id(counter_on);
  - platform: wifi_signal
    name: ${devicename} wifi signal
    update_interval: 600s
  # human readable uptime sensor output to the text sensor above
  - platform: uptime
    name: ${devicename} Uptime in Days
    on_raw_value:
      then:
        - text_sensor.template.publish:
            state: !lambda |-
              int seconds = round(id(uptime_sensor_days).raw_state);
              int days = seconds / (24 * 3600);
              seconds = seconds % (24 * 3600);
              int hours = seconds / 3600;
              seconds = seconds % 3600;
              int minutes = seconds /  60;
              seconds = seconds % 60;
              return (
                (days ? String(days) + "d " : "") +
                (hours ? String(hours) + "h " : "") +
                (minutes ? String(minutes) + "m " : "") +
                (String(seconds) + "s")
              ).c_str();
# Text sensors with general information.
text_sensor:
  # Expose ESPHome version as sensor.
  - platform: version
  # Expose WiFi information as sensors.
  - platform: wifi_info
    ip_address:
    bssid:
  # human readable update text sensor from sensor:uptime
    name: Uptime Human Readable
    icon: mdi:clock-start
script:
  - id: timer1_off
    then:
      - light.turn_on:
          brightness: 40%
      - delay: 15s
      - light.turn_on:
          brightness: 10%
      - delay: 5s
      - light.turn_off: light_mono1
      - lambda: 'id(light_on_1) = 0;'
  - id: timer2_off
    then:
      - light.turn_on:
          brightness: 40%
      - delay: 15s
      - light.turn_on:
          brightness: 10%
      - delay: 5s
      - light.turn_off: light_mono2
      - lambda: 'id(light_on_2) = 0;'
hm…
you have inverted: true in binary sensor, which means that zero on GPIO causes sensor to go to ON, so i guess you should use filter “delayed_on” , not “delayed_off”… ?
Good point, but I’m pretty sure that input value is inverted before filters are applied, therefore the delayed_off filter is getting the “correct” value. But I will test it.
I strongly doubt it… if i remember correctly i’ve had similar issues when i was starting with esphome.
Should be like that, if not, it should be considered bug.
Hm…that’s not a filter, but input specification at the base…
Yes. So active low input is first inverted to represent ON. Then delayed_on filter is used to eliminate glitches. The value has to be longer than loop cycle and in this case can be set very long for better filtering.
Ah… i “half-messed up”… :joy: i did wrote (and meant) correctly that it’s delayed_ON correct one to use, not delayed_OFF.
However, you’re right that first input is inverted, of course, otherwise my first claim wouldn’t be true. And exactly because it IS inverted esphome “sees” pin going from one to zero as if it would go from zero to one.
Now that gpio binary sensor uses interrupts (as default), interferences might cause different results than before. Before gpio was read in loop, so some tiny spikes were likely missed.
Could be hf interferences if your wiring between opto and gpio is long. Likely not.
Or could be parasitic coupling on your mains wiring. Is the “switched L” wire running together with other wiring (that carry current) for long distances?
First try software filtering with long on-delay, if it doesn’t work well, disconnect your sensor and measure the voltage on that L wire during your problematic hours.
I learned from my experiences that
  • built-in pull-up (or pull-down) resistors are not enough, especially if external device (sensor, switch…) is not on the PCB, but on the wire (even short one). It’s just too high valued and as such tends to catch all kinds of noise. I use external resistors 10k down to 4k7 (even 2k2), depending on expected wire length. I’ve had cases where even sensor on the same PCB caused random toggles with built-in resistor only.
  • it’s always a good idea to program at least small “on” delay
  • if wire is long screened cable is recommended, of course tying screen to GND. Either (any kind of) screened network cable or alarm cable (usually 2x0.5 + 4 or 6x 0.25mm2) is perfect.
as for original question: sometimes it helps adding a small capacitor from gpio to GND (like 100n, or even in the range of uF if delayed on is not a problem).
That’s the easiest trick and effective in most cases (if not battery powered).
OP shows 10k external resistors, could be lower though.
Thanks everyone for their inputs. I was fiddling with delayed_xxx filters and finally found a definition, that works as expected.
The delayed_on didn’t work, light was continuously turning on and off.
I removed the inverted: true and instead inverted the condition logic in on_state: ... from - binary_sensor.is_on: to - binary_sensor.is_off:
Then I changed the filter to delayed_on_offwith 100ms value.
This allowed me to remove my additional filter with global variable counter in interval: section.
The code got simplified, the whole interval section was removed.
I reconfigured all 3 devices and after almost 48h not a single light up has occurred.
So this is the final definition of the binary sensor:
globals:
  - id: light_on_1
    type: int
    initial_value: "0"
binary_sensor:
  - platform: gpio
    pin:
      number: GPIO13
      mode:
        input: true
        pullup: true
    internal: true
    filters:
      - delayed_on_off: 100ms
    on_state:
      then:
        - if:
            all:
              - binary_sensor.is_off: power_sense_1   # input is inverted
              - lambda: 'return id(light_on_1) == 0;'
            then:
              - light.turn_on:
                  brightness: 100%
            else:
and the delayed off (exit light) script:
script:
  - id: timer1_off
    then:
      - light.turn_on:
          brightness: 40%
      - delay: 15s
      - light.turn_on:
          brightness: 10%
      - delay: 5s
