Power sensor has values but no diagram in details
i have a tasmota power current sensor. In my lovelace dashboard there are the values as diagram, but if i click on the diagram to see details i see only a history bar with value points.
See picture.
What should i change to see these values also as diagram?
The sensor requires a unit_of_measurement.
If you can’t add this directly to the tasmota device you can use customize:
thanks, that was simple.
