When looking athe the unit of measure W is correct but the decible point is incorrect as in it show 385W and it should be 38.5W and I cannot seem to be able to change it
What integration is this coming from? Sounds like an issue with it that you should report.
As a temporary fix, you could use a template sensor.
From the Tyua official integration. It’s a double outdoor power point.
I don’t know how to make a template sensor to correct the issue. It’s very annoying as I cannot use the information to calculate usage as in right now it is displaying 7324W and it should be 732.4W that’s a massive difference
