Power Switch shows wrong status after power loss
I have a Gosund SP111 power switch on my fridge for alarm purposes.
After I found out, the power switch is always off after power loss (whch is not good on a fridge for obvious reasons) I didn’t want to store the previsous state on its flash since it wears out the flash.
However, I added:
esphome:
  platform: ESP8266
  arduino_version: 2.5.1
  board: esp8285
  on_boot:
    priority: -10
    then:
      - switch.turn_on: relay
This works, the switch is on after a power loss.
However, the status in home assistant shows the device as “off”. If I click on it, it shows as on, without triggering the switch (it just stays as is). After that, everything works normally.
How can I get the correct on/off state after power loss?
Why not set restore_mode: ALWAYS_ON on the switch directly?
Thats the same result, the switch is turned on but initially shows as “off”.
Can you show your relay config?
You could also try decreasing the priority (try -100) to make sure everything is ready so that the state can be sent to home assistant.
Yes, sure, thanks.
I will try!
# Enable Home Assistant API
api:
ota:
  password: "xxx"
wifi:
  ssid: "xxx"
  password: "xxx"
  fast_connect: on
  ap:
    ssid: "xxx"
    password: "xxx"
captive_portal:
substitutions:
  devicename: "gosund_1"
  upper_devicename: "Gosund 1"
  # Higher value gives lower watt readout
  current_res: "0.00244"
  # Lower value gives lower voltage readout
  voltage_div: "715"
esphome:
  platform: ESP8266
  board: esp8285
  on_boot:
    priority: -10
    then:
# Enable logging
logger:
  baud_rate: 0
# see: https://esphome.io/components/time.html
time:
  - platform: homeassistant
# Enable Web server
web_server:
  port: 80
text_sensor:
  - platform: version
    name: "${devicename} - Version"
    icon: mdi:cube-outline
binary_sensor:
  - platform: status
    name: "${devicename} - Status"
    device_class: connectivity
  # toggle relay on/off
  - platform: gpio
    pin:
      number: GPIO13
      mode: INPUT_PULLUP
      inverted: True
    on_press:
      - switch.toggle: button_switch
  - platform: wifi_signal
    name: "${devicename} - Wifi Signal"
    update_interval: 60s
    icon: mdi:wifi
  - platform: uptime
    name: "${devicename} - Uptime"
    icon: mdi:clock-outline
  - platform: total_daily_energy
    name: "${devicename} - Todays Usage"
    power_id: "power_wattage"
    filters:
      # Multiplication factor from W to kW is 0.001
      - multiply: 0.001
    unit_of_measurement: kWh
    icon: mdi:calendar-clock
  - platform: adc
    pin: VCC
    name: "${devicename} - VCC Volt"
    icon: mdi:flash-outline
  - platform: hlw8012
    sel_pin:
      number: GPIO12
      inverted: True
    cf_pin: GPIO05
    cf1_pin: GPIO04
    change_mode_every: 4
    current_resistor: ${current_res}
    voltage_divider: ${voltage_div}
    update_interval: 3s
    current:
      name: "${devicename} - Ampere"
      unit_of_measurement: A
      accuracy_decimals: 3
      icon: mdi:current-ac
    voltage:
      name: "${devicename} - Volt"
      unit_of_measurement: V
      accuracy_decimals: 1
    power:
      name: "${devicename} - Watt"
      unit_of_measurement: W
      icon: mdi:gauge
status_led:
  pin:
    number: GPIO02
    inverted: True
output:
  - platform: gpio
    pin: GPIO00
    inverted: true
switch:
    name: "${devicename} - Switch"
    icon: mdi:power
    optimistic: true
    turn_on_action:
    turn_off_action:
      - switch.turn_off: relay
  - platform: gpio
    pin: GPIO15
#    restore_mode: ALWAYS_ON
# tried that one as well with same result
Still shows as off with -100 :frowning:
Your switch has no state feedback from the relay. That’s why it is getting out of sync. Instead of using optimistic: true use a state template:
switch:
    icon: mdi:power
    lambda: |-
      if (id(relay).state) {
        return true;
      } else {
        return false;
    turn_on_action:
    turn_off_action:
Now the switch knows the state of the relay if something other than the switch changes it (like your boot sequence).
I understand. Thanks for explaining!
That does the trick! :slight_smile:
