Power usage reading on Shelly RGBW2
I managed to flash RGBW2 with ESPHome and so far it works as expected.
The only problem I have is getting power usage measurements. I have added A0 GPIO pin as ADC and it’s changing value as I increase the power, but it’s not linear.
I took measurements at different percentage and this is how the graph looks like:
Values:
Brightness in % A0 readout
poweroff 0,41602
0% 0,41602
10% 0,41602
20% 0,41699
30% 0,41699
40% 0,41797
50% 0,41992
60% 0,4248
70% 0,42871
80% 0,43555
90% 0,44141
100% 0,45117
It looks like exponential growth, but I can’t seem to get the correct function for proper calculation. Also it would be great to make it more linear as one changes the brightness.
Did anyone solve this?
My config if anyone needs it:
substitutions:
  devicename: shelly_rgbw2_generic
  friendly_name: Generic firmware for shelly
  device_description: Shelly LED dimmer
esphome:
  platform: ESP8266
  # Set modwifi on shelly devices since they have 2MB of flash
  board: modwifi
wifi:
  ssid: !secret wifi_ssid
  # Should make wifi signal better (https://www.die-welt.net/2020/04/controlling-roller-shutters-using-a-shelly-25-esphome-and-home-assistant/)
  power_save_mode: none
  manual_ip:
    static_ip: 192.168.50.69
    gateway: !secret ip_gateway
    subnet: !secret ip_subnet
    dns1: !secret ip_dns1
  ap:
    ssid: ${friendly_name}
    password: !secret ap_password
captive_portal:
# Enable logging
logger:
# Enable Home Assistant API
api:
ota:
time:
  # Sync RTC time with HA
  - platform: homeassistant
text_sensor:
  # Sensor with esphome version and fw build time
  - platform: version
  # Extra wifi info from device
  - platform: wifi_info
    ip_address:
    ssid:
    bssid:
  # Reports the WiFi signal strength
  - platform: wifi_signal
    update_interval: 60s
  # Reports how long the device has been powered (in hours) since last reboot
  - platform: uptime
    filters:
      - lambda: return x / 3600;
    unit_of_measurement: "h"
  # Analog input (power usage)
  - platform: adc
    pin: A0
    update_interval: 1s
switch:
  - platform: restart
# Pins for output are found on
# https://translate.google.com/translate?sl=auto&tl=en&u=https%3A%2F%2Fbitekmindenhol.blog.hu%2F2019%2F03%2F30%2Fshelly_rgbw2
binary_sensor:
  # HA sensor showing if device is connected
  - platform: status
  # Switch button
  - platform: gpio
    pin:
      number: GPIO5
      #mode: INPUT_PULLUP
      #inverted: True
    on_click:
      then:
        - light.toggle:
    #internal: true
output:
  - id: pwm_r
    platform: esp8266_pwm
    pin: 12
    frequency: 1000 Hz
    # min_power: 0.06
  - id: pwm_g
    pin: 15
    frequency: 1000 Hz
    # min_power: 0.06
  - id: pwm_b
    pin: 14
    frequency: 1000 Hz
    # min_power: 0.06
  - id: pwm_w
    pin: 4
    frequency: 1000 Hz
    # min_power: 0.06
light:
  - platform: rgbw
    default_transition_length: 0.3s
    red: pwm_r
    green: pwm_g
    blue: pwm_b
    white: pwm_w
The ADC is quite non-linear at the extreme ends of it’s range.
You have a table of measurements, use the linear calibration transform map: Sensor Component — ESPHome
Yes, I just found out about calibrate-linear yesterday. I will try this option tomorrow.
Hey @mmz did you finally calibrate your rgbw2 power consumption.
Hi, did you have any success?
Got mine for 1 LED fo 12V 2W:
  - platform: adc
    pin: A0
    update_interval: 5s
    accuracy_decimals: 4
    internal: true
    unit_of_measurement: W
    accuracy_decimals: 1
    device_class: power
    lambda: return id(current_raw).state;
    filters:
      - calibrate_linear:
        - 0.4000 -> 0.0
        - 0.4043 -> 0.14
        - 0.4053 -> 0.20
      - multiply: 12 # 12V lamp
Did you find out how to do it without having to calibrate it? I am using the config below and even though it “works”, it still feels hackish and it’s only thanks to the fact I have a multimeter and get the values. Shelly is able to do it on stock firmware, so do you know what’s the limitation of getting it right from the beginning as well?
substitutions:
  device_name: bottommirror
esphome:
  platform: ESP8266
  board: esp01_1m
logger:
api:
ota:
wifi:
  manual_ip:
    static_ip: 192.168.0.29
    gateway: 192.168.0.1
    subnet: 255.255.255.0
light:
  - platform: cwww
    name: "Bottom Bathroom Mirror"
    cold_white: ${device_name}_out_ch3
    warm_white: ${device_name}_out_ch4
    cold_white_color_temperature: 6536 K
    warm_white_color_temperature: 2650 K
    constant_brightness: false
# Example output entry
output:
  - platform: esp8266_pwm
    pin: GPIO12
    frequency: 1000 Hz
    pin: GPIO15
    frequency: 1000 Hz
    pin: GPIO14
    frequency: 1000 Hz
    pin: GPIO4
    frequency: 1000 Hz
    name: "${device_name} - WiFi Signal"
  - platform: uptime
    name: "${device_name} - Uptime"
    icon: mdi:clock-outline
  - platform: uptime
    name: "${device_name} - Uptime Seconds"
    on_raw_value:
      then:
        - text_sensor.template.publish:
            state: !lambda |-
              int seconds = round(id(uptime_sensor).raw_state);
              int days = seconds / (24 * 3600);
              seconds = seconds % (24 * 3600);
              int hours = seconds / 3600;
              seconds = seconds % 3600;
              int minutes = seconds /  60;
              seconds = seconds % 60;
              return (
                (days ? String(days) + "d " : "") +
                (hours ? String(hours) + "h " : "") +
                (minutes ? String(minutes) + "m " : "") +
                (String(seconds) + "s")
              ).c_str();
  - platform: adc
    pin: A0
    name: "${device_name} - adc"
    update_interval: 5s
    internal: true
    name: "${device_name} - Power"
    device_class: power
    update_interval: 5s
    filters:
      - calibrate_linear:
        - 0.39551 -> 0.0
        - 0.43750 -> 1.5834
      - multiply: 24 # 24V strips
  - platform: total_daily_energy
    name: "${device_name} - Total Daily Energy"
    power_id: my_power
    filters:
        - multiply: 0.001
    unit_of_measurement: kW
# Enable time component to reset energy at midnight
time:
  - platform: sntp
text_sensor:
    icon: mdi:clock-start
switch:
  - platform: restart
    name: "${device_name} - Restart"
Can I ask where you measured the value 1.5834? Is this a current from measuring in series?
The ADC on an ESP8266 is reporting a voltage (not current) from 0-1V (assuming its a bare chip), so 0.39551V and 0.43750V. If one were to open up an RGBW2 to look at where A0 is wired (resistors , etc) one could calculate the current (I think).
In any case, a measurement like yours should be fine and isn’t really a hack at all.
PS Note the ADC is has 1024 levels so 0.0009765625V steps (assuming its linear).
