Hi
I’m having an issue in trying to monitor the energy consumption of my kettle.
Using a metering plug I saw that it draws 3k watts when heating water and it’s on a smart switch so I can see when the kettle is available (it auto switches off after 3.5 mins).
I created a virtual power sensor for my robo vacuum too and that works fine, but for some reason the kettle sensor isn’t being recorded at all.
I tested the condition in DevTools | template and it’s working correctly, returning “True” when both conditions are met.
Anyone have any ideas as to why it’s not recording it’s use?
(the only real difference is the use of "name: " in the YAML)
- platform: powercalc
name: Kettle Energy Metering
entity_id: switch.innr_plug_2_on_off
calculation_enabled_condition: "{{ is_state('switch.innr_plug_on_off', 'on') and (states('sensor.frient_zhemi101_smartenergymetering')) | float > 3000 }}"
fixed:
power: 3000
