Are you able to test this on your instance as well, by removing device_tracker
from manifest.json and restarting HA?
Yes started up okā¦although I did just realise I am not currently using the device_tracker option as I put a power meter on that device.
Hey! First of all thank you, awesome plugin!
Iām trying to do something but it seems I donāt know how!
I have my Smart TV which is connected to the Home Assistant and also i have the Soundbar which is not smart so i have nothing related to it in the home assistant. But the soundbar itās always the same state as the TV.
So I have added a sensor for the TV:
- platform: powercalc
entity_id: media_player.upstairs_living_tv
standby_power: 0.5
fixed:
power: 100
states_power:
source|Live TV: 110
source|XBOX: 140
And then I wanted to create a new sensor for the Soundbar which uses the state of the same entity_id (the tv) but unfortunately i canāt do this.
This is how i tried to do it:
name: Upstairs Living Soundbar
unique_id: upstairs_living_soundbar
standby_power: 3.5
fixed:
power: 20
Itās there any way I could create this sensor based on the state of TV?
Thank you!
Currently only a single powercalc configuration is allowed per entity_id
For now you could solve this by introducing a template sensor sensor.upstairs_living_soundbar
which just returns the state of media_player.upstairs_living_tv
. And than use this template sensor as an input for Upstairs Living Soundbar.
Another approach would be to just add 3.5 to the TV consumption.
I understand your usecase and would be useful if this was supported by powercalc without the need of an extra entity. Could you create a feature request on the github issue tracker for this? I am not sure if I will be able to do it because there is a reason I put this limitation in place.
Perfect! Donāt know why I didnāt think of that ! Thank you
In the end, maybe is having the same question, i did it like this:
Create a Template Sensor with the same state as the TV
template:
- sensor:
- name: Upstairs Living Soundbar
state: "{{ states('media_player.upstairs_living_tv') }}"
Then add a powercalc sensor for that entity
entity_id: sensor.upstairs_living_soundbar
standby_power: 3.5
fixed:
power: 20
I canāt seem to get a group sensor working.
I have the following under sensors:
create_group: all kitchen lights
entities:
- entity_id: light.kitchen
light.kitchen is a group created by Hue.
I have auto discovery enabled in global config, so i donāt have defined entities for each light:
powercalc:
enable_autodiscovery: true
scan_interval: 00:01:00 #Each minute
create_energy_sensors: true
create_utility_meters: true
utility_meter_types:
- hourly
- daily
- weekly
- monthly
- yearly
Could this be causing the issue?
My understanding is that i should get a sensor.all_kitchen_lights_power ?
Edit: Iāve just tried with an entity for one of the lights rather than a group of lights and that appeared to work fine.
The create_group
purpose is to create an aggregate power and energy sensor for all underlying individual entities. As you already discovered entity_id
always must be an individual light.
With the include functionality you have an option to automatically include all entities of a light group, but I am not sure if this is working for Hue groups already. Could be that it only works for native HA light groups. I am unable to test this atm, but will have a look into that because that seems useful to me.
Thanks for the quick reply.
I could probably get away with include area, i can see include group would require setting up a group config which would probably add more lines to the config than just adding the individual light entities.
Just wanted to let you know I added a new function to powercalc which will make your life easier.
Now itās possible with a one liner to create a group sensor for all powercalc entities of a given domain, for example ālightā.
You can do that as follows:
powercalc:
create_domain_groups:
- light
This will create a sensor āAll light powerā, and also energy and utility_meters.
Has been released in latests beta v0.19.0-beta.2.
Btw. this will add ALL lights to the group sensor. When you want more granular control you need to use the existing way to create groups.
Hi bramski, thanks for this, it was exactly what I have been looking for!
I have just updated to v0.19.0-beta.2 and added that to my config and it has created the new group total entity.
I canāt seem to use the group on the energy dashboard since it doesnāt seem to have a corresponding āstatisticā. All the other āenergyā entities added by powercalc have statistics.
You have to wait a bit to have statistics gathered. Should appear after an hour or something like that. Does it work now?
Unfortunately not, all other powercalc energy entities have statistics, but not the powercalc.all_light_energy one.
Hmm ok. Could you create an issue on github please? Will have a look into this next weekend.
@Fillius I have create the github issue Fix grouped domain sensor in energy dashboard by bramstroker Ā· Pull Request #621 Ā· bramstroker/homeassistant-powercalc Ā· GitHub. Was able to reproduce this issue and have a potential fix. I am testing this currently, need to wait a bit to check if its working.
Keep your eye on the v0.19 beta releases.
Thatās perfect thanks, I hadnāt had chance to get on my desktop to create it yet.
Iāll keep an eye out.
Iāve just updated to beta 7 and itās now fixed and working. The statistic exists and can be added to the energy dashboard.
Thanks for looking at this.
I have no questions, problems or requests. I just wanted to thank you for this awesome component. Itās a leap forward to monitoring my energy consumption. Would love to see it incorporated into the main home assistant repository.
Edit: nevermind the core integration, saw your comment and completely understand!
Thanks for your kind words. I have no plans to get this incorporated in the HA repository as this would take a great amount of effort, and also I want to keep the component fast moving.
Just wanted to let you guys know we have hit the 100 supported lights mark, which is a huge milestone for the project.
I want to thank all contributers for their efforts. Keep them coming.
This integration is absolutely fantastic, Iāve got a load of Hue lights and itās autodiscovered almost all of them and data is coming into HA. Perfect!
Iāve been checking out the documentation and trying to use a combination of nesting and HA Light Groups to create my power/energy config. Just wondered if this was supposed to be possible as when I add the following to my sensor config the integration breaks.
create_group: All Lights Energy
entities:
- create_group: Downstairs Lights Energy
entities:
- create_group: Living Room Lights Energy
include:
group: light.hue_living_room_lights
- create_group: Kitchen Lights Energy
include:
group: light.kitchen_lights
- create_group: Upstairs Lights Energy
entities:
- create_group: Bedroom Lights Energy
include:
group: light.bedroom
- create_group: Bedroom2 Lights Energy
include:
group: light.bedroom2
Hopefully itās just me screwing up the code but this would be super helpful in my setup.
Cheers
Spence
