The component supports input_boolean
so create one, set it to true and then set up this in powercalc:
- platform: powercalc
entity_id: input_boolean.freezer
fixed:
power: 30
fixed:
power: 30
Yes this would be the best solution. The component code relies a lot on an entity existing in Home Assistant, so would be quite some effort to support your use case.
@OzGav very nice! Thank you! I
@bramski I donât think a workaround would be required, OzGavâs solution actually makes a lot of sense
Thanks to the both of you!
Hey all,
Would there be any reason why this template is not updating with sensors from this component?
- sensors:
all_lights_energy:
friendly_name: "All Lights Energy"
unit_of_measurement: kWh
value_template: >-
{{states('sensor.bedroom_ceiling_energy') | float + states('sensor.bedroom_left_energy') | float + states('sensor.bedroom_right_energy') | float + states('sensor.conservatory_ceiling_1_energy') | float + states('sensor.conservatory_ceiling_2_energy') | float + states('sensor.conservatory_ceiling_3_energy') | float + states('sensor.dining_ceiling_energy') | float + states('sensor.floor_lamp_energy') | float + states('sensor.iris_1_energy') | float + states('sensor.iris_2_energy') | float + states('sensor.lounge_ceiling_energy') | float + states('small_lamp_energy') | float + states('sensor.nursery_ceiling_energy') | float}}
attribute_templates:
state_class: total_increasing
device_class: energy
icon: mdi:counter
Also, this other one is updating but when itâs added to the energy dashboard for an individual device it doesnât so a bar for the usage?
- sensors:
hot_tub_energy:
friendly_name: "Hot Tub Energy"
value_template: >-
{{states('sensor.cleverspa_energy') | float + states('sensor.cleverspa_bubbles_energy') | float}}
icon: mdi:counter
If I use the energy entity on its own eg sensor.cleverspa_energy it works fine. But I want to put 2 sensors together.
Thanks for any help
Iâm not at home to check my exact config but two things I can think of. Firstly, I believe for the bar graphs to appear on the energy page they have to be recorded in the database. So check your config and make sure they are included in the RECORDER section
Next not sure your sensor templates are setup correctly as per here Template - Home Assistant (I think you are using the legacy format so this may not matter but canât hurt updating to current format?)
I think it should be
- template:
- sensor:
- name: âHot Tub Energyâ
state: >-
icon: mdi:counter
Edit: for the first one I would carefully check that all of the light energy sensors have a value. If you have any unknowns it might be generating an error. In the link to the Template section In the docs have a look at the âconsiderationsâ section
@OzGav Good suggestion to use the new format. You are missing a quote after Hot Tub, and a wrong quote at the beginning.
@AlexGreenUK I also have no clue why your sensors are not working. Any errors in the logs? Maybe try removing certain sensors from the template until you find the culprit. Is this template working correctly from developer tools?
I just created a new section in the Wiki with some examples how to create groups. Hope this also helps other to setup template sensors correctly.
I have so much lights and adding for every light an extra entry into the configuration yaml is not that nice. So a good idea could be to at least enable a possibility to work with wildcards like:
entity_id: light.hue_color_livingroom_*
as I have 4 of the same type or even let us filter on models
model: "Hue color candle"
as a result the component adds all with standard values whenever the model is âHue color candleâ.
Thanks for this cool component
Lukas
Thanks fixed. Thatâs what happens when I try and do this on the go on the iPad!
I have put all my energy stuff in a package so that the configuration.yaml
stays manageable. Packages - Home Assistant
See https://github.com/bramstroker/homeassistant-powercalc/issues/169. This is a similar request. You can add your idea there. This is a big complex feature request which will require lot of development effort. I will consider but canât promise I will do it anytime soon.
Yes I also manage it this way. All my power sensors contained in a single package. Itâs also a one time configuration. Most people are not adding new lights on a weekly basis.
Thanks.
I cant get the system up and running for all lights without lut support. getting the following errors:
2021-09-11 10:24:55 ERROR (MainThread) [custom_components.powercalc.sensor] Skipping sensor setup light.lightstrip_wohnzimmer: Model not found in library (manufacturer: Signify Netherlands B.V., model: LCL002)
2021-09-11 10:24:55 ERROR (MainThread) [custom_components.powercalc.sensor] Skipping sensor setup light.lightstrip_klavier: Model not found in library (manufacturer: Signify Netherlands B.V., model: LST002)
2021-09-11 10:24:55 ERROR (MainThread) [custom_components.powercalc.sensor] Skipping sensor setup light.lightstrip_esszimmer: Model not found in library (manufacturer: OSRAM, model: Plug 01)
2021-09-11 10:24:55 ERROR (MainThread) [custom_components.powercalc.sensor] Skipping sensor setup light.deckenlampe_esszimmer: Model not found in library (manufacturer: 3A Smart Home DE, model: LXN-1S27LX1.0)
2021-09-11 10:24:55 ERROR (MainThread) [custom_components.powercalc.sensor] Skipping sensor setup light.kristalllampe: Model not found in library (manufacturer: OSRAM, model: Plug 01)
2021-09-11 10:24:55 ERROR (MainThread) [custom_components.powercalc.sensor] Skipping sensor setup light.stehlampe_klavier: Model not found in library (manufacturer: OSRAM, model: Plug 01)
my configuration looks like this:
entity_id: light.lightstrip_klavier
mode: linear
linear:
min_power: 0.3
max_power: 20.0
entity_id: light.lightstrip_esszimmer
mode: fixed
fixed:
power: 20.0
entity_id: light.deckenlampe_esszimmer
mode: fixed
fixed:
power: 50.0
entity_id: light.kristalllampe
mode: fixed
fixed:
power: 15.0
entity_id: light.stehlampe_klavier
mode: fixed
fixed:
power: 20.0
no idea what is missing/wrong with that.
This is actually a bug which I fixed yesterday see https://github.com/bramstroker/homeassistant-powercalc/pull/214. However the fix is not released yet. Will release a new version 0.7.0 containing this fix today. You can remove mode: fixed
, mode: linear
from configuration, this will be automatically set correctly.
edit
Just released v0.7.0. Let me know if this solves your issue.
you are great, working fine now
Is it possible to to /powercalc/data
own folder?
I just have few Gledopto bulbs that probably are similar to some Signify bulbs just I will made some small modifications to Signify files. Temporary solution for me.
I did it, in fact, but update deleted my folders.
Yes. have a look at custom_model_directory
Oh, I overlooked it, sorry.
Two more Q:
A. Do I need to add an entry for every sensor or can I use it as a global configuration?
B. Can I put that subfolder with custom light models into /powercalc/data/
directory? Or it will be erased during the update?
Yes you need to add the setting for each sensor you want to have use a custom light definition for
/powercalc/data/
You have to put it in a subdirectory under your home asssitant config
directory, when you put it in /powercalc/data
it will be overwritten next update.
So you could create config/powercalc_custom_models/my_light
for example.
Is there also an overview of manual settings for devices which are used by many people, like e.g. Google Nest speakers. That would make it more easy to add those, so not everybody has to measure outputs themselves if they want to add it.
No, not yet. Maybe I will consider into extending the light model library with other kind of devices/appliances, but I have not plans on doing that short term yet.
