Kotitonttu
(TonttuTapuli)
February 26, 2018, 7:11am
1
Helloy
I’m trying to make a relay control switch in my Raspberry Pi device. I need this device to return the state of relays after power loss. Is this possible? I’ve red all most of the previous posts but those don’t seem work for me. I’m also having some odd behaviour with my MQTT backup. Basicly, it only returns some states of the 4 switches and not all - you can not ever tell which relay it is backing up. The automation script works if there’s only 1 relay switch. Currently I dont have Raspberry at my location so I’m using other board for developing. Here’s my yaml:
#Restart & Debugging
#sudo systemctl restart home-assistant@homeassistant && sudo journalctl -f -u home-assistant@homeassistant | grep -i 'error'
homeassistant:
latitude: !secret home_lat
longitude: !secret home_lon
elevation: !secret home_elev
time_zone: !secret home_time_zone
unit_system: metric
frontend:
config:
http:
api_password: !secret http_password
mqtt:
broker: localhost
username: !secret mqtt_username
password: !secret mqtt_password
protocol: 3.1
keepalive: 60
#account details in /home/homeassistant/.homeassistant/secrets.yaml
mqtt_statestream:
base_topic: homeassistant
include:
entities:
- switch.rele1
- switch.rele2
- switch.rele3
- switch.rele4
binary_sensor 11:
- platform: mqtt
state_topic: "homeassistant/switch/rele1/state"
retain: true
payload_on: "on"
payload_off: "off"
qos: 1
binary_sensor 21:
- platform: mqtt
state_topic: "homeassistant/switch/rele2/state"
retain: true
payload_on: "on"
payload_off: "off"
qos: 1
binary_sensor 31:
- platform: mqtt
state_topic: "homeassistant/switch/rele3/state"
retain: true
payload_on: "on"
payload_off: "off"
qos: 1
binary_sensor 41:
- platform: mqtt
state_topic: "homeassistant/switch/rele4/state"
retain: true
payload_on: "on"
payload_off: "off"
qos: 1
automation 0:
hide_entity: true
platform: homeassistant
event: start
condition:
condition: template
value_template: "{{ is_state('binary_sensor.rele1sensor', 'on') }}"
- service: switch.turn_on
entity_id: switch.rele1
automation 1:
hide_entity: true
event: start
condition:
condition: template
value_template: "{{ is_state('binary_sensor.rele2sensor', 'on') }}"
entity_id: switch.rele2
automation 2:
hide_entity: true
event: start
condition:
condition: template
value_template: "{{ is_state('binary_sensor.rele3sensor', 'on') }}"
entity_id: switch.rele3
automation 3:
hide_entity: true
event: start
condition:
condition: template
value_template: "{{ is_state('binary_sensor.rele4sensor', 'on') }}"
entity_id: switch.rele4
#Testting switches
switch:
platform: command_line
switches:
rele1:
command_on: "echo 1"
command_off: "echo 0"
rele2:
rele3:
rele4:
#These are only here for testing purposes
#switch:
# - platform: rpi_gpio
# ports:
# 17: rele1
# 27: rele2
# 22: rele3
# invert_logic: true
#switch 12:
# ports:
# 5: rele4
# invert_logic: false
Switches start in the ‘off’ mode so I dont need the turn_off automation scripts - just the turn_on.
I have already modified Mosquitto to save db every 30s and NOT save on change. This was suggested in other forum post. Do you think that saving every change would work? I could actually test this after posting this plea for help.
Could you push me in the right direction? Any help is appreciated. Thanks!
Kotitonttu
(TonttuTapuli)
February 26, 2018, 8:20am
2
My mosquitto conf looks like this:
# Place your local configuration in /etc/mosquitto/conf.d/
# A full description of the configuration file is at
# /usr/share/doc/mosquitto/examples/mosquitto.conf.example
pid_file /var/run/mosquitto.pid
persistence true
persistence_location /var/lib/mosquitto/
log_dest file /var/log/mosquitto/mosquitto.log
include_dir /etc/mosquitto/conf.d
autosave_interval 30
autosave_on_changes true
Autosave seems to have zero effect on the persistence/retainability of relay switches. Regardless of how you setup interval or whether changesave is true or false.
Kotitonttu
(TonttuTapuli)
February 26, 2018, 1:24pm
3
I got this working finally.
Here’s the config file that did it:
#root@pine64:/home/homeassistant/.homeassistant# cat configuration.yaml
homeassistant:
unit_system: metric
customize:
switch.rele1:
hidden: true
switch.rele2:
hidden: true
switch.rele3:
hidden: true
switch.rele4:
hidden: true
frontend:
config:
http:
recorder:
include:
domains:
# - switch
- input_boolean
mqtt:
broker: localhost
protocol: 3.1
keepalive: 60
automation:
- alias: rele1naa
hide_entity: true
platform: state
entity_id: input_boolean.rele1ohjaus
to: 'on'
- alias: rele1nuu
hide_entity: true
platform: state
to: 'off'
- service: switch.turn_off
- alias: rele2naa
hide_entity: true
platform: state
entity_id: input_boolean.rele2ohjaus
to: 'on'
- alias: rele2nuu
hide_entity: true
platform: state
to: 'off'
- alias: rele3naa
hide_entity: true
platform: state
entity_id: input_boolean.rele3ohjaus
to: 'on'
- alias: rele3nuu
hide_entity: true
platform: state
to: 'off'
- alias: rele4naa
hide_entity: true
platform: state
entity_id: input_boolean.rele4ohjaus
to: 'on'
- alias: rele4nuu
hide_entity: true
platform: state
to: 'off'
- alias: rele1auton
hide_entity: true
event: start
condition:
condition: state
state: 'on'
- alias: rele1autoff
hide_entity: true
event: start
condition:
condition: state
state: 'off'
- alias: rele2auton
hide_entity: true
event: start
condition:
condition: state
state: 'on'
- alias: rele2autoff
hide_entity: true
event: start
condition:
condition: state
state: 'off'
- alias: rele3auton
hide_entity: true
event: start
condition:
condition: state
state: 'on'
- alias: rele3autoff
hide_entity: true
event: start
condition:
condition: state
state: 'off'
- alias: rele4auton
hide_entity: true
event: start
condition:
condition: state
state: 'on'
hide_entity: true
event: start
condition:
condition: state
state: 'off'
input_boolean:
rele1ohjaus:
icon: mdi:thermometer-lines #https://materialdesignicons.com/cheatsheet
rele2ohjaus:
icon: mdi:temperature-celsius
rele3ohjaus:
icon: mdi:power-settings
rele4ohjaus:
icon: mdi:lightbulb-on-outline
switch:
switches:
rele1:
rele2:
rele3:
rele4:
#switch 2:
# platform: rpi_gpio
# ports:
# 17: rele1
# 27: rele2
# 5: rele4
#switch 3:
# ports:
# 22: rele3
Thank you for your moral support
