Hello folks,
any powerstrip (aka Multi Plug Extension Sockets aka Electrical multi-outlets) compatible with Hassio?
There are a lot of different products but no one with an explicit Hassio compatibility.
Thanks a lot
Hello folks,
Thanks a lot
How many plugs do you want?
The Quirky pivot power genius works with HA via the Wink integration (no hub required) but only has 2 controllable outlets.
https://www.amazon.com/dp/B00GN92MC6/ref=cm_sw_r_cp_apa_i_BmGpCbR28AW1X
It also can be retrofit with an esp8266 in order to get local mqtt support. https://github.com/w1ll1am23/pivot_power_genius_mqtt
Thanks.
Ops! I forgot to write that I need a powerstrip with EU plugs (Italy, France or Germany standard).
Ooo yeah that makes a difference. Can’t help with that.
