Hi all,
Just installed a new garage door with motor (Powertech PG120). The motor has an optional module to connect with wifi and android APP to control and see the status of the door.
The module is this one:
http://www.jovision.epizy.com/porton-electrico/308-modulo-wifi-para-app-eyeopen-motor-powertech-sp4309.html
I have realized my motor has a pin header with the (G, RX, Tx, V, R) so I connected a uart port and I captured the output:
Open the door to 100%
$V1PKF0,21,Opening;src=0016516
$V1PKF0,17,Opened;src=0001
$V1PKF1,B9-28.25.35.32.26.27.1A.1D.17.11.FF-FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF
Close the door to 0%
$V1PKF0,21,Closing;src=0016516
$V1PKF0,17,Closed;src=0001
$V1PKF1,0-28.25.35.32.26.27.1A.1D.17.11.FF-B.D.B.D.11.11.16.13.19.18.FF
Open to about 50% and stop
$V1PKF0,21,Stopped;src=0016516
$V1PKF1,6C-2A.2A.38.31.23.27.FF.FF.FF.FF.FF-FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF
close a litle bit from previous status
$V1PKF1,66-2A.2A.38.31.23.27.FF.FF.FF.FF.FF-FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF
Again to 50% aprox
$V1PKF1,55-2A.2A.38.31.23.27.FF.FF.FF.FF.FF-FF.FF.FF.D.14.FF.FF.FF.FF.FF.FF
to 75% aprox
$V1PKF1,88-2A.2A.38.31.23.2A.26.1E.FF.FF.FF-FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF
With other remote (Source is different)
$V1PKF0,21,Closing;src=FB9126F
$V1PKF0,21,Opening;src=FB9126F
$V1PKF0,21,Stopped;src=FB9126F
$V1PKF1,98-2A.2A.38.31.23.2A.26.1E.FF.FF.FF-FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF
close to 0%
$V1PKF0,17,Closed;src=0016516
$V1PKF1,0-2A.2A.38.31.23.2A.26.1E.FF.FF.FF-B.D.B.D.12.10.16.15.1F.FF.FF
open to 50% aprox
$V1PKF0,22,LightToggle;src=0001
$V1PKF1,68-28.27.34.2E.26.FF.FF.FF.FF.FF.FF-FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF
Close to 0%
$V1PKF1,0-28.27.34.2E.26.FF.FF.FF.FF.FF.FF-B.C.B.D.11.11.FF.FF.FF.FF.FF
Open and close using the buttons from motor (source 0001)
$V1PKF0,18,Opening;src=0001
$V1PKF0,18,Closing;src=0001
$V1PKF1,0-28.27.37.FF.FF.FF.FF.FF.FF.FF.FF-8.C.FF.FF.FF.FF.FF.FF.FF.FF.FF
if I type somthing with the keyboard
NAK@
NAK`
NAK`
NAK`
NAK`
NAK`
NAK
Of this line “$V1PKF1,B9-28.25.35.32.26.27.1A.1D.17.11.FF-FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF”
the first block B9 (Hex) is 185 in dec and this is when the gate is 100% open. I guess is the position of the gate. The other values I don’t understand them.
There should be a command to send open and close orders, but I don’t know how to discover them. And I don’t have the wifi module to sniff the dialog
I have no programing skills, but I would like to share with you what I find.
Best regards
