Hi. You seem to have a problem with the sensor configuration, which means that HASS is not able to grab your data from Todoist. My code only kicks in after that, so to speak.
Did you follow the exact instructions provided in my README, not the other add-on’s README?
When setting things up I always advise ensuring you’re seeing data from Todoist before any other configurations of my add-on settings. This can be done be checking Developer tools / States and filtering for the sensor entity you created.
About the Today view, I don’t know exactly how it works since I don’t use it. But you should be able to re-create it in Power-Todoist with the date filtering options, which are quite powerful.
I think my original issue might have been as simple as a typo, not sure as I napalmed and started over copying your code exactly and I can load data from a project.
RE: the Today part though, again, I’m very very new to all of this. I fly jets for a living so this is a whole new rodeo. No matter what filters I use, they are always restricted to the original project defined in the code (under project_id). So even if I figure out the date filtering options, which I haven’t, seems all other filters I’ve tried only pull from the originally define project. But my today is from all sorts of projects (see image)
I’m so confused how people use todoist without using Today! You are not the only one. I feel like a todo list is all about knowing what you need to do today on any given project. Todoist is so powerful and so many ways to use it, I’m just surprised at how many people while digging into this are telling me they don’t. It’s the home screen. HA and these tools are so awesome because they can fit what we all need, but damn that makes it harder to address all uses.
Sorry I’m dumb. I know most of the people reaching out have something to offer but then again, I used to do software QA and if anything, I learned coding to the lowest common denominator is a good thing. I am the lcd now.
It’s not that people don’t use “Today” in todoist, they just don’t use it from inside Home Assistant.
Todoist is a great mobile and web app, that’s what you should be using to get your tasks going.
From within HASS, your experience is always going to be a lot more limited (but potentially more connected to your home devices, or to home users).
One of the primordial limitations is the project. Since this card loads information from the Todoist API as a sensor, and it queries the API specifying a project_id, it will always be limited to a single project, you’re never going to see combined information from several projects.
The most you could get is having several sensors, one for each project, and then several cards showing information from each, filtered by dates if you want.
I thought I’d circle back here since I started using this card again. The current version is working exactly as I hoped when I first tried it. And I also wanted to share a photo, in case folks were having difficulties visualizing how or why this might be practical:
This is a Google Nest Hub Max in my kitchen. Tasks are only those due today (or overdue, but that doesn’t happpen), and are in time-order (thus breakfast before lunch, etc).
Thanks for all of your hard work on this - it’s greatly appreciated!
I would also like to see more people sharing their stories of how they use the card, I’m really curious if anyone is actually using this for a full Kanban, or to trigger Home Assistant automations, etc
Basically - I’ve been playing with espresense and I’d like to be able to use it hand in hand with Todoist; So if I enter a particular room (read: espresense senses me in said room), I’d like for an automation or script to check if a task is complete, and if not, prompt me to do it.
I already had issues with executive dysfunction, but a recent cancer diagnosis confirmed also that I’ve been dealing with additional “brain fog” on top of that. So I really need to be reminded more than the average bear.
Thanks for any thoughts you might be able to spare.
Hi! Sorry to hear those news - I will pray for you
I am not sure how to achieve what you want, but I think it should be possible. With scripts, you could do basically anything, but that requires some Python which is not my thing.
With simple automations, it should also be possible, I think you could try first creating a sensor directed specifically at the task you want to know if it is done. So, instead of having a sensor that gets everything from Todoist API, so that my add-on then filters and organizes what to show, you would have a separate sensor (totally unrelated to my add-on) that grabs a specific task and (probably using a value template) compresses the returned info into a simple boolean true/false indicating if the task is done.
This should then be straight-forward to use in the automation.
Good luck and if you get it working, tell us how you did it. If you have difficulties I suggest asking in the forums, in a more generic format (“I have this sensor that grabs everything, help me get a duplicate sensor with just the state of one item”).
Thank you on all counts - I think I’m following what you’re saying.
The mini pc I have running Proxmox (which holds HA) decided to kick the bucket (better it than me?) so I’ll have to attack this again once I’m back online.
hey @pgr ! As I noted in my last comment, I (unintentionally) nuked my Proxmox server and then made the decision to quasi start over rather than rebuild. Well, I rebuilt enough to be able to copy information over but the new system is much better equiped for anything. I digress…
I’ve been doing a LOT of copy/pasting, including cards that I had working just fine beforehand that are now showing this instead:
The sensors are pulling in data (you can see it’s due today):
Any ideas? Surgery is Monday, and I’d at least like to have this working again in the kitchen (the one you saw in the photo I posted a month or so ago) so my caretaker will be able to mark down when she’s fed the furkids.
Hi. I think this has to be a sensor problem, getting data from sensors is really happening before my code ever gets to do anything.
I suggest a full OS-level reboot, sometimes I’ve seen this “unblock” sensors.
Other than that, check that you really have fresh data showing in the sensor, not just today’s date which could have been set days ago, but add a task with a funny name and see it appear.
Hi, thx for this implementation.
I now tried a few hours and got the entity filed with values from the webside and can see them under the developer stuff.
Now I put the js file in the config/ww folder manual (it was missed after the instalation) but in the UI I only get this:
Fixed it. Problem was that I put all sensors in my sensor.yaml.
But I need to relocate the 'platform: command_line" - part to my configuration.yaml and have to change it like this:
This was a discussion we had on the original Todoist-List thread, but I’ve just created a new task and hoped to have it marked completed within the automation (will paste below how we’d done this previously) but it looks like Todoist has changed the arg from ID numbers to random characters. Would this still work?
Will be tomorrow morning. I’ll circle back and let you know if it worked.
It may be worth noting that I canceled my paid Todoist sub. I’ve still got a few months on it, but I’ve consolidated my tasks down to be under the free usage.
Good news - it worked! So apparently those IDs can now include letters too, which seems to be the default for all my tasks - curiously/amusingly, the old IDs seem to still work too!
