Prana ventilation - heat exchanger - control from Home Assistant
Could you try testing if Tasmota IR recognizes the codes from your remote?
It’s true it doesn’t use ESPHome which is very easy to use and might be a little hit and miss with ESP32 and Tasmato IR (ESP8266 would be preferable) but, if signal is identified, then with both a IR blaster and a receiver placed near the AC you can also use the original remote of AC and have it in sync with HA.
