Hi, I am using Islamic Prayer Times integration to play on my speakers at home. Problem with that I can’t match the exact prayer times for Diyanet/Turkey. The workaround for now is to use offset ±… The problem is I need to change my offsets daily…
I found a solution with note-red flow… basically it triggers hours from diyanet website everyday at 00:00 abd create txt file. From there i have automation that read the data
