With appdaemon sky’s the limit. I would really like both possibilities depending on situation. But as I wrote haven’t tested the dashboard at all yet so I don’t know all of its intended usages yet
OK, I added it to the list - it would be easy to write a widget that AppDaemon could send messages to to change the widget (or from HA as well for that matter). You can already do it from HA with 2 states, if you want more I’ll look at a generalization of the binary idea.
Great! Thanks Andrew!
Eagerly awaiting your public beta!
/R
Would love to contribute a modest CSS skin or two. This is my current dashboard with my CSS changes.
That looks awesome!
Consider yourself signed up as the official skins man - I am rubbish at look and feel
I’ve kept the css layouts virtually identical - I just added code to pick up different css on a per dashboard basis. I also just added in the ability to use MDI icons at @rpitera’s suggestion.
Thermostat control (or input slider) would be awesome.
Already on the list
if it is finished every entity or element from HA should be possible to see or control.
as someone fairly new to HA and only just got occusim via AppDaemon working, I would love to try this out!
I’m definitely down!! I currently use the 3 dashboard around my home to make it easier for my not so tech savvy family and in-laws (which at times seems a little often looking back… ). Besides, no better way to annoy the hell outta my husband!
OMG - I’m aroused by this.
This is bloody beautiful.
Definitely up for a Beta, good timing too as I’m planning on a clean test install on something slightly beefier than a pi over the weekend.
As a fairly new user, are my only prerequisites in order to prepare for this dashboard, to install and learn AppDeamon? Anything else? I think this will be fantastic!
I /wanted/ to like the old HADashboard, but it was so awkward compared to everything else. I wanted to like AppDaemon… and DID like it very much
Oh my, now you’re putting the peanut butter and chocolate together? I’m so in.
The new dashboard will require an AppDaemon install yes, but you don’t need to learn anything about Apps if you don’t want to - there will be some simple file based config for the dashboards is all.
Happy to be a tester! Cheers.
If You need more testers, I’m here, too
Thanks all - I’ll post an announcement when I am ready.
