Hey there,
I’m working on my first core contribution and ran in the pre-commit script error shown below. Any ideas? I will go through the pre-commit script now.
❯ git commit -m "xxx"
[INFO] Installing environment for https://github.com/psf/black.
[INFO] Once installed this environment will be reused.
[INFO] This may take a few minutes...
An unexpected error has occurred: CalledProcessError: command: ('/Users/user/.cache/pre-commit/repoorx8kr7l/py_env-python3/bin/python', '-mpip', 'install', '.')
return code: 1
expected return code: 0
stdout:
Processing /Users/user/.cache/pre-commit/repoorx8kr7l
Installing build dependencies: started
Installing build dependencies: finished with status 'done'
Getting requirements to build wheel: started
Getting requirements to build wheel: finished with status 'done'
Preparing wheel metadata: started
Preparing wheel metadata: finished with status 'error'
stderr:
ERROR: Command errored out with exit status 1:
command: /Users/user/.cache/pre-commit/repoorx8kr7l/py_env-python3/bin/python /Users/user/.cache/pre-commit/repoorx8kr7l/py_env-python3/lib/python3.9/site-packages/pip/_vendor/pep517/_in_process.py prepare_metadata_for_build_wheel /var/folders/nc/vg00848974ggdcn6gq43qsyhnldw01/T/tmppxgjw9tp
cwd: /private/var/folders/nc/vg00848974ggdcn6gq43qsyhnldw01/T/pip-req-build-4bmxdj4h
Complete output (46 lines):
/private/var/folders/nc/vg00848974ggdcn6gq43qsyhnldw01/T/pip-build-env-p2uka2pv/overlay/lib/python3.9/site-packages/setuptools_scm/git.py:88: UserWarning: "/private/var/folders/nc/vg00848974ggdcn6gq43qsyhnldw01/T/pip-req-build-4bmxdj4h" is shallow and may cause errors
warnings.warn(f'"{wd.path}" is shallow and may cause errors')
File "/Users/user/.cache/pre-commit/repoorx8kr7l/py_env-python3/lib/python3.9/site-packages/pip/_vendor/pep517/_in_process.py", line 280, in <module>
main()
File "/Users/user/.cache/pre-commit/repoorx8kr7l/py_env-python3/lib/python3.9/site-packages/pip/_vendor/pep517/_in_process.py", line 263, in main
json_out['return_val'] = hook(**hook_input['kwargs'])
File "/Users/user/.cache/pre-commit/repoorx8kr7l/py_env-python3/lib/python3.9/site-packages/pip/_vendor/pep517/_in_process.py", line 133, in prepare_metadata_for_build_wheel
return hook(metadata_directory, config_settings)
File "/private/var/folders/nc/vg00848974ggdcn6gq43qsyhnldw01/T/pip-build-env-p2uka2pv/overlay/lib/python3.9/site-packages/setuptools/build_meta.py", line 166, in prepare_metadata_for_build_wheel
self.run_setup()
File "/private/var/folders/nc/vg00848974ggdcn6gq43qsyhnldw01/T/pip-build-env-p2uka2pv/overlay/lib/python3.9/site-packages/setuptools/build_meta.py", line 150, in run_setup
exec(compile(code, __file__, 'exec'), locals())
File "setup.py", line 48, in <module>
setup(
File "/private/var/folders/nc/vg00848974ggdcn6gq43qsyhnldw01/T/pip-build-env-p2uka2pv/overlay/lib/python3.9/site-packages/setuptools/__init__.py", line 153, in setup
return distutils.core.setup(**attrs)
File "/opt/homebrew/Cellar/[email protected]/3.9.4/Frameworks/Python.framework/Versions/3.9/lib/python3.9/distutils/core.py", line 108, in setup
_setup_distribution = dist = klass(attrs)
File "/private/var/folders/nc/vg00848974ggdcn6gq43qsyhnldw01/T/pip-build-env-p2uka2pv/overlay/lib/python3.9/site-packages/setuptools/dist.py", line 434, in __init__
_Distribution.__init__(self, {
File "/opt/homebrew/Cellar/[email protected]/3.9.4/Frameworks/Python.framework/Versions/3.9/lib/python3.9/distutils/dist.py", line 292, in __init__
self.finalize_options()
File "/private/var/folders/nc/vg00848974ggdcn6gq43qsyhnldw01/T/pip-build-env-p2uka2pv/overlay/lib/python3.9/site-packages/setuptools/dist.py", line 743, in finalize_options
ep(self)
File "/private/var/folders/nc/vg00848974ggdcn6gq43qsyhnldw01/T/pip-build-env-p2uka2pv/overlay/lib/python3.9/site-packages/setuptools/dist.py", line 750, in _finalize_setup_keywords
ep.load()(self, ep.name, value)
File "/private/var/folders/nc/vg00848974ggdcn6gq43qsyhnldw01/T/pip-build-env-p2uka2pv/overlay/lib/python3.9/site-packages/setuptools_scm/integration.py", line 24, in version_keyword
dist.metadata.version = _get_version(config)
File "/private/var/folders/nc/vg00848974ggdcn6gq43qsyhnldw01/T/pip-build-env-p2uka2pv/overlay/lib/python3.9/site-packages/setuptools_scm/__init__.py", line 173, in _get_version
parsed_version = _do_parse(config)
File "/private/var/folders/nc/vg00848974ggdcn6gq43qsyhnldw01/T/pip-build-env-p2uka2pv/overlay/lib/python3.9/site-packages/setuptools_scm/__init__.py", line 127, in _do_parse
version = _version_from_entrypoints(config) or _version_from_entrypoints(
File "/private/var/folders/nc/vg00848974ggdcn6gq43qsyhnldw01/T/pip-build-env-p2uka2pv/overlay/lib/python3.9/site-packages/setuptools_scm/__init__.py", line 65, in _version_from_entrypoints
version = _call_entrypoint_fn(root, config, ep.load())
File "/private/var/folders/nc/vg00848974ggdcn6gq43qsyhnldw01/T/pip-build-env-p2uka2pv/overlay/lib/python3.9/site-packages/setuptools_scm/__init__.py", line 46, in _call_entrypoint_fn
return fn(root, config=config)
File "/private/var/folders/nc/vg00848974ggdcn6gq43qsyhnldw01/T/pip-build-env-p2uka2pv/overlay/lib/python3.9/site-packages/setuptools_scm/git.py", line 127, in parse
node_date = wd.get_head_date() or date.today()
File "/private/var/folders/nc/vg00848974ggdcn6gq43qsyhnldw01/T/pip-build-env-p2uka2pv/overlay/lib/python3.9/site-packages/setuptools_scm/git.py", line 67, in get_head_date
return datetime.strptime(date_part, r"%Y-%m-%d").date()
File "/opt/homebrew/Cellar/[email protected]/3.9.4/Frameworks/Python.framework/Versions/3.9/lib/python3.9/_strptime.py", line 568, in _strptime_datetime
tt, fraction, gmtoff_fraction = _strptime(data_string, format)
File "/opt/homebrew/Cellar/[email protected]/3.9.4/Frameworks/Python.framework/Versions/3.9/lib/python3.9/_strptime.py", line 349, in _strptime
raise ValueError("time data %r does not match format %r" %
ValueError: time data 'gpg: Signature made Wed Apr 28 16:50:04 2021 CES' does not match format '%Y-%m-%d'
WARNING: Discarding file:///Users/user/.cache/pre-commit/repoorx8kr7l. Command errored out with exit status 1: /Users/user/.cache/pre-commit/repoorx8kr7l/py_env-python3/bin/python /Users/user/.cache/pre-commit/repoorx8kr7l/py_env-python3/lib/python3.9/site-packages/pip/_vendor/pep517/_in_process.py prepare_metadata_for_build_wheel /var/folders/nc/vg00848974ggdcn6gq43qsyhnldw01/T/tmppxgjw9tp Check the logs for full command output.
ERROR: Command errored out with exit status 1: /Users/user/.cache/pre-commit/repoorx8kr7l/py_env-python3/bin/python /Users/user/.cache/pre-commit/repoorx8kr7l/py_env-python3/lib/python3.9/site-packages/pip/_vendor/pep517/_in_process.py prepare_metadata_for_build_wheel /var/folders/nc/vg00848974ggdcn6gq43qsyhnldw01/T/tmppxgjw9tp Check the logs for full command output.
Check the log at /Users/user/.cache/pre-commit/pre-commit.log
❯ /Users/user/.cache/pre-commit/repoorx8kr7l/pyproject.toml
