I have a Daikin AC which was very easy to discover and autocreate with the daikin integration. I got a thermostat card in lovelace to control everything I need.
entity: climate.dg
type: thermostat
climate.dg has the following attributes:
hvac_modes:
- fan_only
- dry
- cool
- heat
- heat_cool
- 'off'
min_temp: 7
max_temp: 35
target_temp_step: 1
fan_modes:
- Auto
- Silence
- '1'
- '2'
- '3'
- '4'
- '5'
preset_modes:
- away
- none
swing_modes:
- 'Off'
- Vertical
- Horizontal
- 3D
current_temperature: 26
temperature: 24
fan_mode: Silence
preset_mode: none
swing_mode: 'Off'
friendly_name: DG
supported_features: 57
Unfortunatley, current_temperature is very unreliable when the AC is off. I would like to show the temperature from a temperature sensor (e.g. sensor.temp_dg) that is in the same room as the AC unit instead in lovelace.
What would be the easiest way to accomplish this ?
Regards, gadget
