Preload stream config for camera
This should be rally easy and as you will detect I am new to this.
It is suggested in the camera integration documentation that Preload stream can be used as a way of reducing latency when streaming from an ip camera.
Question for me… the hopefully easy bit, is “What’s the syntax for the config entry?”
I have
stream:
In my config file. I have tried variations on the preload bit but Hvaing failed at all of them the question is: Whre does the Preload bit go? An example would be great…
Many thanks.
