Premier Inn bookings for Home Assistant
Logo Premier Inn bookings for Home Assistant
This component provides details of a specified Premier Inn booking and adds sensors to Home Assistant which can be used in your own automations.
GitHub Release
License
hacs_badge
Project Maintenance
Enjoying this? Help me out with a :beers: or :coffee:!
coffee
Installation through HACS
There is an active PR to get this into HACS, once that is merged then you can install the Premier Inn integration by searching for it there in HA instance.
Until then you will have to add this repository manually:
Go to HACS → 3 dot menu → Custom Repositories:-
Paste https://github.com/jampez77/PremierInn into Repository field and select Integration
Now you should be able to find it in HACS as normal.
You can install the Premier Inn integration by searching for it there in HA instance.
Manual Installation
Use this route only if you do not want to use HACS and love the pain of manually installing regular updates.
  • Add the premierinn folder in your custom_components folder
Usage
Each entry requires a booking reference, arrival date, surname and the country that the hotel is located in. This information can be found on your booking email confirmation. Additionaly you can select an existing calendar and\or ask the integration to create a new one to display date based information such as check in/out times.
Contributing
Contirbutions are welcome from everyone! By contributing to this project, you help improve it and make it more useful for the community. Here’s how you can get involved:
How to Contribute
  1. Report Bugs: If you encounter a bug, please open an issue with details about the problem and how to reproduce it.
  2. Suggest Features: Have an idea for a new feature? I’d love to hear about it! Please open an issue to discuss it.
  3. Submit Pull Requests: If you’d like to contribute code:
    • Fork the repository and create your branch from main.
    • Make your changes in the new branch.
    • Open a pull request with a clear description of what you’ve done.
Data
The integration will add calendar entities for check in / out times plus a longer one for the duration of the stay. The duration entity will contain booking and hotel information within the description.
A booking will automatically be removed when check out time arrives. The will remove all assocaited entities but NOT events added to calendars.
There should also be a geo location entity created for the hotel itself, this will put the hotel on your map in HA. It will contain the relevat hotel information as attributes.
  • Hotel Information
    • Postal Address
    • Name
    • Parking Information
    • Directions
    • Contact Details
    • GPS location
  • Booking Information
    • Check in / out times
    • Arrival / Departue dates
    • Room Name
    • Outstanding Balance
    • Currency Code
    • Booking Reference
    • Number and details of guests
    • Reservation Status
