Preparing home assistant
stuck in the landingpage for many times
i use the vmware in Windows10 with the official vmdk files, i’ve tried 8.1-5 haos releases, but all failed.
here is the log from landingpage
s6-rc: info: service s6rc-oneshot-runner: starting
s6-rc: info: service s6rc-oneshot-runner successfully started
s6-rc: info: service fix-attrs: starting
s6-rc: info: service fix-attrs successfully started
s6-rc: info: service legacy-cont-init: starting
cont-init: info: running /etc/cont-init.d/udev.sh
[18:43:16] INFO: Using udev information from host
cont-init: info: /etc/cont-init.d/udev.sh exited 0
s6-rc: info: service legacy-cont-init successfully started
s6-rc: info: service legacy-services: starting
services-up: info: copying legacy longrun supervisor (no readiness notification)
services-up: info: copying legacy longrun watchdog (no readiness notification)
s6-rc: info: service legacy-services successfully started
[18:43:16] INFO: Starting local supervisor watchdog...
22-08-23 18:43:17 INFO (MainThread) [__main__] Initializing Supervisor setup
22-08-23 18:43:17 INFO (MainThread) [supervisor.bootstrap] Initializing Supervisor Sentry
22-08-24 02:43:17 INFO (MainThread) [supervisor.bootstrap] Seting up coresys for machine: qemux86-64
22-08-24 02:43:17 INFO (SyncWorker_0) [supervisor.docker.supervisor] Attaching to Supervisor homeassistant/amd64-hassio-supervisor with version 2022.08.3
22-08-24 02:43:17 INFO (SyncWorker_0) [supervisor.docker.supervisor] Connecting Supervisor to hassio-network
22-08-24 02:43:17 INFO (SyncWorker_0) [supervisor.docker.interface] Cleanup images: ['ghcr.io/home-assistant/amd64-hassio-supervisor:2022.07.0']
22-08-24 02:43:18 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state CoreState.INITIALIZE
22-08-24 02:43:18 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
22-08-24 02:43:18 INFO (MainThread) [__main__] Setting up Supervisor
22-08-24 02:43:18 INFO (MainThread) [supervisor.api] Starting API on 172.30.32.2
22-08-24 02:43:18 INFO (MainThread) [supervisor.hardware.monitor] Started Supervisor hardware monitor
22-08-24 02:43:18 INFO (MainThread) [supervisor.dbus.manager] Load dbus interface io.hass.os
22-08-24 02:43:18 INFO (MainThread) [supervisor.dbus.manager] Load dbus interface org.freedesktop.systemd1
22-08-24 02:43:18 INFO (MainThread) [supervisor.dbus.manager] Load dbus interface org.freedesktop.login1
22-08-24 02:43:18 INFO (MainThread) [supervisor.dbus.manager] Load dbus interface org.freedesktop.hostname1
22-08-24 02:43:18 INFO (MainThread) [supervisor.dbus.manager] Load dbus interface org.freedesktop.timedate1
22-08-24 02:43:19 INFO (MainThread) [supervisor.dbus.manager] Load dbus interface org.freedesktop.NetworkManager
22-08-24 02:43:19 INFO (MainThread) [supervisor.dbus.manager] Load dbus interface de.pengutronix.rauc
22-08-24 02:43:19 INFO (MainThread) [supervisor.dbus.manager] Load dbus interface org.freedesktop.resolve1
22-08-24 02:43:19 INFO (MainThread) [supervisor.host.info] Updating local host information
22-08-24 02:43:19 INFO (MainThread) [supervisor.host.services] Updating service information
22-08-24 02:43:19 INFO (MainThread) [supervisor.host.sound] Updating PulseAudio information
22-08-24 02:43:19 INFO (MainThread) [supervisor.host.manager] Host information reload completed
22-08-24 02:43:19 INFO (MainThread) [supervisor.host.network] Updating local network information
22-08-24 02:43:20 INFO (MainThread) [supervisor.host.apparmor] Loading AppArmor Profiles: {'hassio-supervisor'}
22-08-24 02:43:20 INFO (MainThread) [supervisor.docker.monitor] Started docker events monitor
22-08-24 02:43:20 INFO (SyncWorker_0) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/amd64-hassio-cli with version 2022.06.0
22-08-24 02:43:20 INFO (SyncWorker_0) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/amd64-hassio-dns with version 2022.04.1
22-08-24 02:43:20 INFO (MainThread) [supervisor.plugins.dns] Updated /etc/resolv.conf
22-08-24 02:43:20 INFO (SyncWorker_0) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/amd64-hassio-audio with version 2022.07.0
22-08-24 02:43:20 INFO (SyncWorker_0) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/amd64-hassio-observer with version 2021.10.0
22-08-24 02:43:20 INFO (SyncWorker_0) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/amd64-hassio-multicast with version 2022.02.0
22-08-24 02:43:20 INFO (MainThread) [supervisor.updater] Fetching update data from https://version.home-assistant.io/stable.json
22-08-24 02:43:25 INFO (MainThread) [supervisor.homeassistant.secrets] Loaded 0 Home Assistant secrets
22-08-24 02:43:25 INFO (SyncWorker_0) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/qemux86-64-homeassistant with version landingpage
22-08-24 02:43:25 INFO (MainThread) [supervisor.homeassistant.core] Starting HomeAssistant landingpage
22-08-24 02:43:25 INFO (MainThread) [supervisor.os.manager] Detect Home Assistant Operating System 8.4 / BootSlot A
22-08-24 02:43:25 INFO (MainThread) [supervisor.store.git] Loading add-on /data/addons/core repository
22-08-24 02:43:25 INFO (MainThread) [supervisor.store.git] Loading add-on /data/addons/git/5c53de3b repository
22-08-24 02:43:25 INFO (MainThread) [supervisor.store.git] Loading add-on /data/addons/git/a0d7b954 repository
22-08-24 02:43:25 INFO (MainThread) [supervisor.store] Loading add-ons from store: 66 all - 66 new - 0 remove
22-08-24 02:43:25 INFO (MainThread) [supervisor.addons] Found 0 installed add-ons
22-08-24 02:43:25 INFO (MainThread) [supervisor.backups.manager] Found 0 backup files
22-08-24 02:43:25 INFO (MainThread) [supervisor.discovery] Loaded 0 messages
22-08-24 02:43:25 INFO (MainThread) [supervisor.ingress] Loaded 0 ingress sessions
22-08-24 02:43:25 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state CoreState.SETUP
22-08-24 02:43:25 INFO (MainThread) [supervisor.resolution.check] System checks complete
22-08-24 02:43:25 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state CoreState.SETUP
22-08-24 02:43:25 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
22-08-24 02:43:25 INFO (MainThread) [supervisor.jobs] 'ResolutionFixup.run_autofix' blocked from execution, system is not running - CoreState.SETUP
22-08-24 02:43:25 INFO (MainThread) [__main__] Running Supervisor
22-08-24 02:43:25 INFO (MainThread) [supervisor.os.manager] Rauc: A - marked slot kernel.0 as good
22-08-24 02:43:25 INFO (MainThread) [supervisor.addons] Phase 'AddonStartup.INITIALIZE' starting 0 add-ons
22-08-24 02:43:25 INFO (MainThread) [supervisor.addons] Phase 'AddonStartup.SYSTEM' starting 0 add-ons
22-08-24 02:43:25 INFO (MainThread) [supervisor.addons] Phase 'AddonStartup.SERVICES' starting 0 add-ons
22-08-24 02:43:25 INFO (MainThread) [supervisor.core] Skiping start of Home Assistant
22-08-24 02:43:25 INFO (MainThread) [supervisor.addons] Phase 'AddonStartup.APPLICATION' starting 0 add-ons
22-08-24 02:43:25 INFO (MainThread) [supervisor.misc.tasks] All core tasks are scheduled
22-08-24 02:43:25 INFO (MainThread) [supervisor.core] Supervisor is up and running
22-08-24 02:43:25 INFO (MainThread) [supervisor.homeassistant.core] Home Assistant setup
22-08-24 02:43:25 INFO (MainThread) [supervisor.host.info] Updating local host information
22-08-24 02:43:25 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state CoreState.RUNNING
22-08-24 02:43:25 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.TRUST/ContextType.SUPERVISOR
22-08-24 02:43:25 INFO (SyncWorker_0) [supervisor.docker.interface] Updating image ghcr.io/home-assistant/qemux86-64-homeassistant:landingpage to ghcr.io/home-assistant/qemux86-64-homeassistant:2022.8.6
22-08-24 02:43:25 INFO (SyncWorker_0) [supervisor.docker.interface] Downloading docker image ghcr.io/home-assistant/qemux86-64-homeassistant with tag 2022.8.6.
22-08-24 02:43:25 INFO (MainThread) [supervisor.host.services] Updating service information
22-08-24 02:43:25 INFO (MainThread) [supervisor.host.network] Updating local network information
22-08-24 02:43:26 INFO (MainThread) [supervisor.host.manager] Host information reload completed
22-08-24 02:43:39 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.DNS_SERVER_FAILED/ContextType.DNS_SERVER
22-08-24 02:43:39 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.DNS_SERVER_IPV6_ERROR/ContextType.DNS_SERVER
22-08-24 02:43:39 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.SECURITY/ContextType.CORE
22-08-24 02:43:39 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.PWNED/ContextType.ADDON
22-08-24 02:43:39 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.FREE_SPACE/ContextType.SYSTEM
22-08-24 02:43:39 INFO (MainThread) [supervisor.resolution.module] Create new suggestion SuggestionType.CREATE_FULL_BACKUP - ContextType.SYSTEM / None
22-08-24 02:43:39 INFO (MainThread) [supervisor.resolution.check] System checks complete
22-08-24 02:43:39 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state CoreState.RUNNING
22-08-24 02:43:44 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
22-08-24 02:43:44 INFO (MainThread) [supervisor.resolution.fixup] Starting system autofix at state CoreState.RUNNING
22-08-24 02:43:44 INFO (MainThread) [supervisor.resolution.fixup] System autofix complete
22-08-24 03:43:25 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state CoreState.RUNNING
22-08-24 03:43:25 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.TRUST/ContextType.SUPERVISOR
22-08-24 03:43:25 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.DNS_SERVER_FAILED/ContextType.DNS_SERVER
22-08-24 03:43:25 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.DNS_SERVER_IPV6_ERROR/ContextType.DNS_SERVER
22-08-24 03:43:25 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.SECURITY/ContextType.CORE
22-08-24 03:43:25 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.PWNED/ContextType.ADDON
22-08-24 03:43:25 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.FREE_SPACE/ContextType.SYSTEM
22-08-24 03:43:25 INFO (MainThread) [supervisor.resolution.check] System checks complete
22-08-24 03:43:25 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state CoreState.RUNNING
22-08-24 03:43:25 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
22-08-24 03:43:25 INFO (MainThread) [supervisor.resolution.fixup] Starting system autofix at state CoreState.RUNNING
22-08-24 03:43:25 INFO (MainThread) [supervisor.resolution.fixup] System autofix complete
22-08-24 04:43:25 INFO (MainThread) [supervisor.updater] Fetching update data from https://version.home-assistant.io/stable.json
22-08-24 04:43:25 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state CoreState.RUNNING
22-08-24 04:43:25 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.TRUST/ContextType.SUPERVISOR
22-08-24 04:43:25 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.DNS_SERVER_FAILED/ContextType.DNS_SERVER
22-08-24 04:43:25 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.DNS_SERVER_IPV6_ERROR/ContextType.DNS_SERVER
22-08-24 04:43:25 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.SECURITY/ContextType.CORE
22-08-24 04:43:25 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.PWNED/ContextType.ADDON
22-08-24 04:43:25 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.FREE_SPACE/ContextType.SYSTEM
22-08-24 04:43:25 INFO (MainThread) [supervisor.resolution.check] System checks complete
22-08-24 04:43:25 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state CoreState.RUNNING
22-08-24 04:43:25 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
22-08-24 04:43:25 INFO (MainThread) [supervisor.resolution.fixup] Starting system autofix at state CoreState.RUNNING
22-08-24 04:43:25 INFO (MainThread) [supervisor.resolution.fixup] System autofix complete
