Is there a way to hide the sensor from the front-end if the device is Away? I currently have custom groups set up and not using the default view. I can hide the sensor if I set “hide_if_away” to true but then it also does not log the activity in the logbook whenever the device is “Away”. It only logs when the device is “Home”. I want to hide the sensor and log the activity when “Away”. Thanks.
groups.yaml:
default_view:
view: yes
icon: mdi:home
entities:
- device_tracker.device1
known_devices.yaml:
device1:
hide_if_away: false
track: true
