Presence detection like alarmo
Hi
Would there, for presence detection, be an integration like alarmo does for alarms?
What I mean is that this integration looks at multiple factors (f.e. Wifi, zone, Bluetooth range,…) to determine if someone is really home.
Rwgarda
Christophe
You can create your own using the Bayesian integration:
Mine looks like this:
There’s an excellent howto here, along with an interactive spreadsheet to work out the maths for you.
I’ll take a look at it, thanks
This is built into HA. Your user can have a number of device tracker entities associated to it (in the settings for your user). If you really need to, you can use a Bayesian sensor as one of these device trackers, but I recommend you pick something that is reliable because otherwise your automations can be flaky.
