I have DuckDNS configured and can remotely access HA externally from the HA app on my iPhone but I can’t for the life of me get it to show up as home or away in the dashboard.
I have:
Device Tracker component shows as ticked in HA on iOS
I’m connecting using my DuckDNS URL
I have the IOS: setup in my configuration.yaml file
Location settings on IOS I have the 4 update sources turned on
I tried to reset the IOS app to deafult
It hasn’t created the known_devices.yaml file if I manually create this file and put my phone in with the MAC Address it shows up but always says away and never updates
-The battery level and state show up, it seems like battery state never updates but battery level does
Is there anything else I can try? I spent a couple of hours on this today and could not get it to work
If you mean device ID on the iPhone app, Yes there is a device ID set… All I have done is add ios: to the configuration.yaml file, installed HomeAssistant app on my iphone and connect to HA on my phone via the DuckDNS URL. I made sure all the device tracking options are enabled in HA on my phone.
