Images currently happy with my KNX Installation but recognise now: I forgot to place some presence detection sensor (Not motion sensors as these are not sensitive)
Now I think to use another wireless standard like Z-Wave or Homematic (totally open on this) to solve this
Any recommendations from you would help. It should be as small as possible and battery powered.
A Presence detection sensor is recognising the tiniest movements. E.g. when you’re typing on a keyboard. A Motionsensor will not “see” this movements but the presence sensor does.
Or you’re laying on your couch. A motionsensor recognises your movement only when you move. A presence sensor recognises the movement of your stomach when you breath.
I read that article, thanks for the information. I still don’t get the difference,for me it sounds like a presence detector is just a ultra sensitive motion detector.
I checked out the presence sensors from the article they work with infrared like most of the motion sensors and they are way too expensive, 70 euro (piccola) or 240 Euros (auro) for one sensor!!!
What would be your use case for this? Do you have currently any situations, in which the light turns off when it should not? I feel like lots of situations where this would be needed, could be solved differently.
Have you ever seen such a sensor live? It’s hard for me to believe, that a motion sensor would be able to detect when I type something on my keyboard or my belly moving when I’m breathing. For this to work the sensor would need to be put in a very specific place and angle due to the way the infrared motion detection works. But I’d be happy to be proved otherwise.
For your scenarios room detection via BLE could be an option. The BLE tags send a signal every second, some even more frequent. I currently have a Raspberry Pi Zero W in each room, which detect the signal of the BLE tags and the strength of the signal. The software room assistant on the Pis will then determine in which room the tag is, based on the signal strength. You can cut a hole in your slippers and put the BLE tags in there or find some other way to have it always on you.
I know this is old AF but figured I’d throw in my 2c. The Hue motion sensors are the only ones I’ve used that aren’t terrible. sonoff, aqura, tuya, none of those are worth even $3 let alone $5 or $10. I have roughly ~25 so some thing expensive is not an option. I have been able to get Hue sensors for $10 each which IMO is a steal, keep your eye out. Ebay is a good bet, I bought 30 of them that were reported as “for parts” because they wouldn’t connect to the hue hub or something. Connected right up to my HA instance every single one.
