Is anyone using Geofency with iBeacon? I tried to select that option, filling there the UUID of a Nut beacon (that I can I discover with an iOS scanner app) but Geofency doesn’t recognize it and it doesn’t trigger in?out events. What’s my mistake? I’ll appreciate your help.
Thank you
Yes I double checked but it doesn’t work. Could you kindly suggest me a way (or a procedure) to discover the right UUID to put in the Geofency settings? That will help me surely. Thank you in advance for your help.
Hi all,
I tried to use the http basic auth function of GeoFency with username and password. However without success.
Is there any way to use it like this in Home Assistant or do I need to transfer my credentials via URL parameters?
I also used it this way in fhem.
Of course I want to use it with https.
Thank you for your help.
Greetings
Edit: „?api_password=„ does not work. I think it is because I do not use API password, but my dedicated user with username and password.
