"Presence" Device Class
I recently got myself a smartthings hub with the plan to integrate it into Homeassistant using the MQTT bridge.
This is working well, but I notice the presence detection (whilst seems to be very reliable) is currently showing as a binary sensor - Whilst I have no issue with this, there currently seems to be no way of identifying binary sensors as ‘Home’ or ‘Away’.
My Request is to add a ‘Presence’ device class.
on = Home
off = Away
Thank you
Doesn’t give you the clean solution your feature request does but a work around to give you the front end report you are looking for in the mean time. Replace the generic names I gave below with your entity_ID and add the new sensor to your front end.
    sensors:
     Name:
        entity_id: binary_sensor.sensor1
        value_template: '{% if is_state("binary_sensor.sensor1", "on") %}Home{% else %}Away{% endif %}'
Added a PR https://github.com/home-assistant/home-assistant/pull/10705
