Presence Does not retain status
I have the following setup:
Two persons and attached to each one of them a device tracker from GPSlogger integration.
In order to save battery, the GPS logger sends the location only if it senses movement.
After the upgrade to version 2022.2.0, when I restart home assistant, the device tracker of GPSlogger does not retain their previous status before the restart and they are displayed as unavailable causing the persons to be displayed as unknown.
In order for them to get the status back the gps logger which is associated to this trackers needs to update again its position and this is not always the case for the reason I have explained before.
Why this does not retain its previous status?
