Hi there,
I want to share my “presence simulator” in case someone needs it.
It does what its name tells:
Case 1: turns on/off lights when I am not at home and the my Risco security system is activated
Case 2: turns on/off light during the night when I am at home and the security system is activated for the garden only
I created one config for each case. If case 1 is activated case 2 does not start. In case 2 is activated case 1 does not run.
Here I’m gonna share just case 2 config since I have completely tested it. Case 1 is not enough tested because covid lockdown…
Anyway, case 2 works fine so maybe case1 may work as well.
This is the automation.yaml component:
# simulatore luci con allarme parziale (non incluso in simulatore)
- alias: Simulatore presenza - looper luci allarme parziale
- platform: state
entity_id: alarm_control_panel.risco_security
to: 'armed_home'
for:
seconds: 60
- platform: state
entity_id: sun.sun
to: 'below_horizon'
- platform: state
entity_id: media_player.tv_soggiorno_2 # the looper does not start if I'm watching TV in the living room
to: 'off'
condition:
condition: and
conditions:
- condition: state
entity_id: input_boolean.presence_simulator
state: 'off'
- condition: state
entity_id: sun.sun
state: 'below_horizon'
- condition: not
conditions:
- condition: state
state: 'on'
repeat:
while:
- condition: and
conditions:
- condition: state
state: 'armed_home'
- condition: state
entity_id: sun.sun
- condition: not
conditions:
- condition: state
entity_id: media_player.tv_soggiorno_2 # the looper stops if living room TV is on
state: 'on'
sequence:
- delay: "00:00:02"
- service: script.turn_on
data_template:
entity_id: "script.simulatore_luce_{{ range(2,5) | random}}" # randomply turn on lights in some rooms (not bed rooms!)
#- wait_template: "{{ is_state('input_boolean.presence_simulator_wait_light', 'off') }}"
- delay: "00:00:02"
- wait_for_trigger:
- platform: state
entity_id: input_boolean.presence_simulator_wait_light
to: 'off'
for: 5
- delay: "00:{{ '{:02}'.format(range(1,31) | random | int) }}:00"
This is the script.yaml component:
simulatore_luce_1:
alias: Simulatore - luce 1 - lampadario bedroom # this light is not turned on in case 2 but just in case 1
sequence:
- service: light.turn_on
entity_id: light.bedroom
- delay: "00:{{ '{:02}'.format(range(5,29) | random | int) }}:00"
- service: light.turn_off
- service: input_boolean.turn_off
simulatore_luce_2:
alias: Simulatore - luce 2 - lampadario tavolo cucina
sequence:
- service_template: > # if someone is in the kitchen the scripts does not turn off the lamp (my wife doesn't like lighting during the night...)
{% if states.light.mobile_bianco_led_inferiore.state == 'off' %}
switch.turn_on
{% elif states.light.mobile_bianco_led_inferiore.state == 'on' %}
switch.turn_on
{% endif %}
entity_id: switch.lampadario_cucina
#- service: switch.turn_on
# entity_id: switch.lampadario_cucina
- service: switch.turn_off
simulatore_luce_3:
alias: Simulatore - luce 3 - lampadario soggiorno piccolo (luce bassa) # this light has a step dimmer with 3 on/off the light is lower
sequence:
entity_id: switch.lampadario_piccolo
- delay: "00:00:01"
- delay: "00:00:01"
- delay: "00:00:01"
- delay: "00:00:01"
- delay: "00:00:01"
simulatore_luce_4:
alias: Simulatore - luce 4 - applique sinistro divano
sequence:
entity_id: switch.applique_sinistra_divano
simulatore_luce_5:
alias: Simulatore - luce 5 - applique destro divano
sequence:
entity_id: switch.applique_destra_divano
- delay: "00:{{ '{:02}'.format(range(5,29) | random | int) }}:00" #random delay
input_booleans.yaml component:
presence_simulator_wait_light:
Of course you need to set up components like Risco security system. In case you use another alarm system you need something else…
Any suggestion is appreciated
Hope it helps!
Gekomax
