In my home I’ve got some logitech squeeze boxes, as well as a yamaha receiver, all of which have basic home assistant integration, which is enough to hit the play / stop button.
In both cases I largely use these to play internet streams. The way these play on each is quite different. In order to build any sane automation rules, like tune into this stream at 7am, you really need a more abstract “set_preset_num(1)” and then some device specific configuration (that you could put in the yaml) for what that would be. On the squeezebox it might be a full url. On the yamaha you have to navigate down a vtuner tree (Bookmarks>Internet>Radio Paradise) to set the internet stream.
Mostly, I wanted to know what kind of top level device interfaces people thought would be good here to get into the contract for the media_player, and then could play around with implementation after.
If there was a play_preset interface that took a number (1…N), it would also allow the media player web component to display a set of preset buttons on the web UI, which would let you do this kind of changing from the UI without having to build a scene for every single one sending down a cryptic media id.
media_player:
platform: yamaha
preset_1: “NET_RADIO: Bookmarks > Internet > Radio Paradise”
preset_2: “NET_RADIO: Bookmarks > Internet > WAMC”
preset_3: “Pandora”
That would both allow media player UI widgets to expose presets, as well as allow other parts of automation to have saved symbols outside of scenes to work with.
