"Press Type event was fired with parameters: {'press_type': 1}"?
I brought some white label Zigbee scene switchers\batter powered button, ZHA says that it has configured them, and the appear to connect OK.
When I go to the automations setting it gives me multiple options in the GUI to trigger an event using the scene switch.
I get:
Fist Button Press
First Button continuous press
First button double clicked
As options
However, when I press the scene switcher non of these events are registered. Instead I get a log entry that says
“Press Type event was fired with parameters: {‘press_type’: 1}”
I’m not sure how to capture this in an automation so that I can actually use it in HA.
The device was unbranded, the device info in HA says “TS0041 by _TZ3000_mrpevh8p”
The device signature data is
“node_descriptor”: “NodeDescriptor(logical_type=<LogicalType.EndDevice: 2>, complex_descriptor_available=0, user_descriptor_available=0, reserved=0, aps_flags=0, frequency_band=<FrequencyBand.Freq2400MHz: 8>, mac_capability_flags=<MACCapabilityFlags.AllocateAddress: 128>, manufacturer_code=4417, maximum_buffer_size=66, maximum_incoming_transfer_size=66, server_mask=10752, maximum_outgoing_transfer_size=66, descriptor_capability_field=<DescriptorCapability.NONE: 0>, *allocate_address=True, *is_alternate_pan_coordinator=False, *is_coordinator=False, *is_end_device=True, *is_full_function_device=False, *is_mains_powered=False, *is_receiver_on_when_idle=False, *is_router=False, *is_security_capable=False)”,
“endpoints”: {
“1”: {
“profile_id”: “0x0104”,
“device_type”: “0x0000”,
“input_clusters”: [
“0x0000”,
“0x0001”,
“0xe000”
“output_clusters”: [
“0x0006”,
“0x000a”,
“0x0019”
“manufacturer”: “_TZ3000_mrpevh8p”,
“model”: “TS0041”,
“class”: “zhaquirks.tuya.ts0041.TuyaSmartRemote0041TOPlusA”
Go to Developer Tools, then click the Event tab
Now type * in the listen field and start the listening.
Click the button press you want and look through the captured events.
With * there all events will be captured, but once you have found the event for the button, then you can narrow it down with a better filter.
Once I’ve determined what the event is, how do i watch for it in an automation?
I get this
event_type: zha_event
  device_ieee: a4:c1:38:bf:47:a5:0f:28
  unique_id: a4:c1:38:bf:47:a5:0f:28:1:0x0006
  device_id: 744a26144b957b782a57805f63035d95
  endpoint_id: 1
  cluster_id: 6
  command: press_type
  args:
    - 0
  params:
    press_type: 0
origin: LOCAL
time_fired: "2024-01-11T19:50:16.486055+00:00"
context:
  parent_id: null
  user_id: null
and this
  endpoint_id: 1
  cluster_id: 6
  command: remote_button_short_press
  args: []
  params: {}
origin: LOCAL
time_fired: "2024-01-11T19:50:16.485302+00:00"
context:
  parent_id: null
  user_id: null
How do I listen for them to trigger and automation?
You should be able to use an event trigger.
OK, an event trigger, but how do I find out what the trigger is for this device when the built in ones seemingly do nothing?
The two you just posted is actual events from that device.
Made an account just to say thank you, this was EXACTLY what I was looking for, didnt know you coudl do this!
